06-06-2012, 05:16 PM
Steve Jackson
Sewer Flush
How long does everyone run their black tank flush system? Last weekend I ran mine for a good 3 to 4 minutes saw the water running clear so I figure all is good. When I got home I went to open the grey water tank and accidentally pulled the sewer handle and needless to say lots of brown water and TP came out. Did I not run the flush long enough? I have also been using the softener and detergent method.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
06-06-2012, 05:19 PM
I always install Geo method before I leave cg and several gallons of water.
To slosh around for trip home.
Ok to leave sit for next trip.
06-06-2012, 05:20 PM
I have run it as long as 30 minutes if I have time and at a site hook up.
06-06-2012, 05:34 PM
Drain the black tank-------------
Right on with the 30 Min flush!!!!!!
I drain the black tank, fill to about 3/4 full with the flush system, drain again, fill again, drain, fill again. Now add about 1/4 tank of water, add your chemicals and you are ready for the next trip. I use septic tank safe
paper, three pods of dish washer soap, a chemical deodorant to keep the smell down.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
06-06-2012, 05:36 PM
It takes a good 15 to 20 minutes for a complete flush.
TP and sludge will form a "dam" at the valve opening and turbo flush water will pile up behind it. You will think you are done; then suddenly a "whoosh" of crud will come out. This will happen several times when flushing.
A clear elbow is a mandatory "option" and everyone should have one.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-06-2012, 06:52 PM
Steve Jackson
WOW! didn't realize it had to run that long. Great advice everyone. I do put the mixture in when I get home but I suppose it would be better at CG for the ride home.
06-06-2012, 07:56 PM
I usually close the gate, run flush for a few minutes, open gate, look for colour of discharge and repeat several times until satisfied all sewer is discharged.
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
06-07-2012, 11:52 AM
2012 Ford F150 4x4, 5.0L, 3.55 2011 Rockwood MiniLite 1809s E2 WDH 600/6000lbs
06-07-2012, 05:31 PM
Thanks for posting the link to the Geo Method site. That's great information. Something to add to my documentation, and to use.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
06-07-2012, 06:28 PM
when I flush my tank I am constantly opening and closing the black tank valve to fill and drain the tank - have had excellent results doing it that way
and I agree with what Herk said about the clear elbow - makes a world of diffrence when you are making sure your tank is clean
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
06-07-2012, 07:17 PM
Steve Jackson
So I keep reading that people close the tank valve while they are flushing the tank. So I take it we can ignore the warning label on the side of trailer that says open valve before flushing tank. My trailer is still under warranty and don't want to do any damage.
06-07-2012, 07:24 PM
perfectly clean ?? probably not
I do about a ten min flush
closing the valve a few times during flush
that build up of water
helps to get clean
depending on angle of RV
may never be perfectly clean
Mountainman
06-07-2012, 08:09 PM
It wont damage anything unless you leave the flusher on and the valve closed where it over flows up the toilet and ruins the inside of your camper
the warning label is there so they cant be sued for someone leaving the valve closed when running the tank flush.
when I open and close the valve I actually watch how much water is being put into the tank - usually only let it go a 1/4 to 1/2 at the most which is below the flusher head
06-07-2012, 08:30 PM
Steve Jackson
Just curious, how do you know when it's 1/4 full? Was it just trial and error?
06-07-2012, 09:19 PM
You ignore limits and warnings at your own risk.
No one will pony up the money if you follow bad advice given here and damage your camper or tow vehicle.
If you understand the reason for the warning or limit and are convinced it does not apply to you, then do what your conscience dictates.
As in all posts and advice on an open forum you will get posts from experts, folks just trying to help, and fools.
They will all sound very convincing.
It is your job to figure out which is which.
06-19-2012, 08:08 PM
I was reading this thread before I left for vacation and I would like to start using the GEO Method. I have looked at several places and all I could find was the liquid Calgon Water Softener (at Wally World). Can someone tell me how much of the liquid Calgon I should use to make a batch of GEO?
06-19-2012, 08:22 PM
Post 8 has the site.
06-20-2012, 05:02 AM
Yes I know but he talks about is how much to use using the crystal type of softener and all I can find is the liquid. Looking for a ballpark conversion.
06-20-2012, 05:54 AM
Walmart has the crystals
06-20-2012, 06:44 AM
The liquid version is the best one to use, IMO.
I use the following method and am very happy with the results.
AFTER every dump:
1 CAP full of Calgon
1 CAP full of laundry soap
in the toilet - flush for 1 minute.
in the bath sink - run hot water for 1 minute
At end of Season prior to winterization:
1/2 bottle of RV-Digest-It and a full tank of water on both black and gray tanks and let stand a MINIMUM of 72 hours. Then turboflush and drain till clear. - Winterize as normal.
