Old 02-19-2018, 10:10 AM   #1
Sewer hook up on 369DS
I just bought a new Georgetown 369DS with two baths. It has a rear sewer connection and a main sewer connection. Do I need two sewer hoses that go into a Y connection when hooked up at the RV park. Thanks in advance look forward to our maiden voyage.
Ron
Ron0211 is offline   Reply With Quote
Old 02-19-2018, 10:26 AM   #2
RSchleder's Avatar
My RV also has a gray water dump valve for the kitchen plus a combined dump for the bathroom gray/black tanks. You really have 3 options, either find a "Y" hose connection, simply move the dump hose, or purchase another hose so you can move/switch the appropriate 90 degree clear end into the campground sewer when dumping.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 02-19-2018, 10:59 AM   #3
Kaadk's Avatar
Do you 'need'? No, technically, you don't. As mentioned above, you can just move the hose from one to the other, or use two hoses or any other combination of options to be able to dump.
But you will 'need' to have a hose on the sewer outlet of the tank that you're dumping at the time of dumping. I've never heard of any rig with two sewer outlets being interconnected, so don't expect to be able to dump everything through only one outlet.
