Old 03-24-2016, 12:03 PM   #11
Helmsey's Avatar
I have a Rhino Flex we purchased in 2009 and no issues. If it starts to lean any poo water that will be a good indication it is time for replacement
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 03-24-2016, 12:45 PM   #12
Too Tall's Avatar
Just carry a backup just in case
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-24-2016, 12:46 PM   #13
BamaBob's Avatar
Originally Posted by harleyguy View Post
How often do you replace the sewer hose ? Mine is about 4 years old and seems to be in good shape but I don't want to hold on to it too long and get a liquid surprise. Also what brand do you suggest for replacement?
Two years ago I would have said RhinoFlex is the only way to go. That was before we got our Lippert WasteMaster. So many features that make this superior: outside rib support & smooth interior hose make for NO clogs or TP jams; the hose material is very thick - probably 2-3X that of a Rhinoflex; the heavy duty nozzle with sure grip rubber grommet & clear tube +on/off lever. Oh, and the cam-lock connector; never have to worry about a bayonet connection loosening up (or the hose separating from the bayonet connector!)
Best.Sewer.Hose.Period.
(Full disclosure: Yes, I won the $150 system in a essay competition, but it does not change my opinion of the product--proof: I sold our 5er and of course the WasteMaster went with it. I will be buying a new WasteMaster for our MoHo!)
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-04-2016, 02:14 PM   #14
Some guy in back...
Smile
Originally Posted by wahoonc View Post
I use a Sewer Solution... hoses are about 12 years old and still going strong! Longevity of the stinky slinky is going to depend on the quality and how much UV exposure and use it has gotten. Once it feels brittle or starts to show signs of aging I would consider replacement. I have seen some super el cheapo versions fail the first time out. The Rhino is a decent hose for the money and should last quite a while if taken care of.
Aaron
I'm with Aron-I'Ve used a Sewer Solution on every hardside trailer we've had in the last 17 years. I carry a slinky for "emergencies" and I have never used it. I also don't need any holders, supports, gutters, ski slopes, pigs or adapters. I do carry 3 pieces of 1" PVC in my bumper for those odd locations where we are too far from the sewer opening. It's the smarter way to dump!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-04-2016, 09:42 PM   #15
Too Tall's Avatar
What is the advantage of this gizmo? Size? Doesn't the sewer dump faster thru a 4" hose? I learn something everyday.
USMC 68 -70
Old 04-04-2016, 10:19 PM   #16
Pill Billy's Avatar
It requires a water input to help macerate the waste/tissue going through it so you can get by with the supplied hose (much smaller than slinky).
The advantages are that the hose does not have corrugations inside, the setup can be used to pump uphill, and you can use this over long distances with tubing/PVC.
Pill Billy is online now   Reply With Quote
Old 04-04-2016, 10:55 PM   #17
Too Tall's Avatar
Could I pump it thru a water hose out into the wood? Or a nearby stream or lake?
USMC 68 -70
Old 04-04-2016, 11:22 PM   #18
I agree completely,..... three yrs., three trailers, never used slinky,......at home nearest I can get to my septic tank clean out is 40' and it's 2' higher than were my tanks are sitting on the trailer, Sewer Solution handles that with no problem and without the need for electricity for a little electric pump,....Sewer Solution, "try it, you might like it"......................
fella10 is online now   Reply With Quote
Old 04-04-2016, 11:57 PM   #19
Uh-Oh... Here it comes..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 04-05-2016, 12:15 AM   #20
Your Fresh Water Tank! Youroo!!
