Old 04-05-2016, 04:11 AM   #21
World Wide Wanderer
wahoonc's Avatar
The main reason I bought it was due to the extremely low sewer connection height on my Airstream as well as the fact my home connection was higher and a bit further away. On my Concord I am planning to reconfigure the mess that was installed at the factory and go with a 12 volt macerator pump. I too have carried a stinky slinky but have never used it. The only disadvantage to the Sewer Solution is the fact you need a pressurized water source for it to work properly. It is a bit slower than a 4" dump line.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-05-2016, 05:25 AM   #22
with the macerator pump you'll need rinse water and I guess that means saving your gray for that purpose, ....not w/SS, that's one(of many) of the things I like about the Sewer Solution, we don't have to save the gray water to rinse behind the black, we actually leave gray open to drain all the time we're hooked up, one less thing to monitor
fella10 is offline   Reply With Quote
Old 04-05-2016, 06:53 AM   #23
Land of the Midnightsun
jjSpeedwagon's Avatar
Originally Posted by dalford View Post
Uh-Oh... Here it comes..
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 04-05-2016, 07:17 AM   #24
Pickin' & Campin'
Originally Posted by youroo View Post
Your Fresh Water Tank! Youroo!!
For those looking for extra storage capacity!
I like it!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-05-2016, 10:41 AM   #25
BamaBob's Avatar
Originally Posted by Too Tall View Post
Could I pump it thru a water hose out into the wood? Or a nearby stream or lake?
Now that everyone has had a good laugh Let's answer your question.
Even macerated, you are pumping raw sewage out of your black tank, so, in a word, no. And double no for the stream or lake (Your daughter & wife might be downstream swimming
All contents from your black and gray tanks should be disposed of in a approved dump facility (either a sewer hookup on your site or a campground dump station).
So why a macerator? A lot of reasons but the biggest ones (I suppose) is a smaller hose, ability to pump uphill, and the big Thetford ones can dump a tank in 1-2 min!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-05-2016, 07:11 PM   #26
World Wide Wanderer
wahoonc's Avatar
When we are at home the gray water goes on the ground into the garden. Black goes into the septic system...ALWAYS! Besides the grass grows greener over the septic field. One small house I had the garden was over the septic field and no one could figure out how I was able to grow such great tomatoes.
When camping in a established campground we follow the rules, occasionally I might bleed of a bit of gray water if it is a heavily wooded campground, but I keep that to a minimum.
Aaron
Aaron & Rhonda
Old 04-05-2016, 07:37 PM   #27
B and B's Avatar
For the first 30 years of camping we dumped the dishpan in the woods beside the site. First TT did not have a gray tank and this went on the ground through a garden hose. Last time I drove to work (this morning) they are pumping waste solids from sewage treatment plant on to farmers fields (restricted use every 5 years). Also it is liquid manure season. So this goes on them fields too.
I recycle (born in Kitchener), collect compost for pickup by the region and I do not see an issue dumping gray water on the ground. In fact during the 80's they built gray tanks in some homes to water grass or the garden.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-05-2016, 07:51 PM   #28
TLAK's Avatar
The Sewer Solution looks great for some situations, but it requires a fresh water connection. Almost all of dump stations I've used don't have a conventional hose, they generally have a rinse hose, but no threaded connector. This could be a problem if you dry camp or use water / electric only and dump on the way out. Am I missing something?
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 04-05-2016, 08:19 PM   #29
Too Tall's Avatar
I really started some sh_t.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-05-2016, 08:22 PM   #30
Who Dares, Wins
doc73's Avatar
As long as it continues to keep flowing down hill...
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
