Old 04-05-2016, 09:04 PM   #31
Too Tall's Avatar
Originally Posted by doc73 View Post
As long as it continues to keep flowing down hill...
Sent from my SAMSUNG-SM-G870A using Tapatalk
:roflb lack:
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-06-2016, 12:11 AM   #32
Originally Posted by Too Tall View Post
I really started some sh_t.
Trouble maker...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 04-06-2016, 05:34 AM   #33
World Wide Wanderer
wahoonc's Avatar
Originally Posted by TLAK View Post
The Sewer Solution looks great for some situations, but it requires a fresh water connection. Almost all of dump stations I've used don't have a conventional hose, they generally have a rinse hose, but no threaded connector. This could be a problem if you dry camp or use water / electric only and dump on the way out. Am I missing something?
I don't typically use dump stations. I avoid the lines and either stay in a sewer site if available or dump when I get home. SS works great in both cases. I do know one person that rigged an outlet from the fresh water tank on their TT and used it to pressurize the SS. Worked well for her.
I want the ability to THOROUGHLY flush and rinse my tanks, that isn't going to happen at your typical dump station.
They do make a gizmo called a water thief/bandit (PC police at work?) that will fit on any faucet threaded or not.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-06-2016, 05:38 AM   #34
World Wide Wanderer
wahoonc's Avatar
Originally Posted by B and B View Post
For the first 30 years of camping we dumped the dishpan in the woods beside the site. First TT did not have a gray tank and this went on the ground through a garden hose. Last time I drove to work (this morning) they are pumping waste solids from sewage treatment plant on to farmers fields (restricted use every 5 years). Also it is liquid manure season. So this goes on them fields too.
I recycle (born in Kitchener), collect compost for pickup by the region and I do not see an issue dumping gray water on the ground. In fact during the 80's they built gray tanks in some homes to water grass or the garden.
Those are "treated" solids...
The biggest issues with dumping gray water on the ground occurs near watersheds and in high use areas. Also a dish pan only holds a couple of gallons at best, not 20+ like many holding tanks. In many areas it has been outlawed an you will get a fine if they find out.
Aaron
Aaron & Rhonda
Old 04-06-2016, 05:52 AM   #35
Aaron
The "Thief/Bandit,s" will not allow any Back Pressure,only Free Flow,UNLESS you add a Hose clamp of some type! Youroo!!
Old 04-06-2016, 07:07 AM   #36
Kenny kustom's Avatar
Aaron
My last three houses, all had grey water fields. Grey has been going in/on the ground forever.
One even had a septic field.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-06-2016, 08:13 AM   #37
B and B's Avatar
Aaron
In any campground I have used in Canada I have never seen a grey dump solution for wash pans or any rules for containment for trailers that don't have the facility. Common sense prevails with anything but as Kenny has mentioned Grey had gone into ground forever. As far as treating the solids here they scoop then out to a truck , add water and spray. Not sure how you treat solid waste.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-06-2016, 09:28 AM   #38
Too Tall's Avatar
Aaron
The soil is a perfect filter, you need to watch more naked and afraid.
USMC 68 -70
Old 04-06-2016, 09:52 AM   #39
I sometimes pee on the ground behind my shop. Am I in trouble?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 04-06-2016, 10:10 AM   #40
Land of the Midnightsun
jjSpeedwagon's Avatar
I don't need the stinky slinky or any high tech dumping mechanisms. My wife and I are early risers and we leave camp ground in the cover of darkness with black tank valve wide open trying to make as many right hand turns as we can before reaching Hwy. Just tryin to keep Amercia a little greener
John & Janice
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
