Old 04-06-2016, 10:26 AM   #41
Some guy in back...
Originally Posted by TLAK View Post
The Sewer Solution looks great for some situations, but it requires a fresh water connection. Almost all of dump stations I've used don't have a conventional hose, they generally have a rinse hose, but no threaded connector. This could be a problem if you dry camp or use water / electric only and dump on the way out. Am I missing something?
TLAK,
I don't think you are missing anything. Since the SS requires a pressurized water source to "power" its jet pump, I always have a grey water hose with me-It's even grey! I never use my freshwater hose for dumping. The SS does incorporate a one-way flow valve, but I prefer a dedicated hose. If the dump station does not have a threaded connection on the rinse hose where I need it, I almost always can use my hose to substitute. In fact, I have never had to use my 4" hose to dump! Other's experience will vary and there are likely to be situations where pressurized water is unavailable, period. In that case, a 4" hose or an electric macerator pump might be required. That is the reason I carry 10' of 4" hose "just in case".
Cheers!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-06-2016, 10:37 AM   #42
Gold Miner At Heart
Papa-t's Avatar
Rhino hose here also. Will last years unless you abuse it. Cheep hoses just don't last like a Rhino.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 04-06-2016, 05:04 PM   #43
Too Tall's Avatar
Originally Posted by ChateauV10 View Post
TLAK,
Cheers!
How do you do it without a connection or do you unscrew their hose completely?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-06-2016, 06:35 PM   #44
World Wide Wanderer
wahoonc's Avatar
Originally Posted by Kenny kustom View Post
My last three houses, all had grey water fields. Grey has been going in/on the ground forever.
One even had a septic field.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I have 3 septic systems on my current house to deal with. Septic fields aren't a problem, except when they don't work or you have too many of them too close together. However in NC it is against the law to dump any form of waste water on the ground in most areas.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-07-2016, 10:00 AM   #45
Some guy in back...
Too Tall, if the rinse hose connection is available/visible and it looks like I can remove it, I have and used my hose and then re-attached "their" hose.
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
Old 04-07-2016, 10:21 AM   #46
Too Tall's Avatar
Ok, got it. thanks.
USMC 68 -70
