Old 12-26-2011, 02:50 PM   #1
Dallas Texas
TexasBBQ's Avatar
Sewer hose and equipment
We recently got our 5th wheel Cardinal from a couple and it didn't come with the sewer hose, hose support or any other item required for that process. I certainly understand why.
I'm looking on Amazon and see a lot of different types of hoses and supports. From the Comco RihnoFlex 39761, Comco 39625 2 piece kit, to other brands.
Amazon.com: Camco 39761 RhinoFLEX 15' RV Sewer Hose Kit with Swivel Fittings: Automotive
Amazon.com: Camco 39625 RV Revolution Swivel RV Sewer Kit: Automotive
This is our first camper with this kind of need so I'd like to get ya'lls opinion. Do I need to get 15 or 20 foot unit? Is there a brand better then another? Does the plastic hose support work ok? Any lessons learned that might help would be appreciated. I don't want any surpprises if you know what I mean.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 12-26-2011, 03:03 PM   #2
3 Happy Campers's Avatar
Here’s my sewer hose mod.
It’s from Lippert & ran $180.
I have a 15’ Rhinoextreme hose in it. (You can use any kind you want)
I keep another 5’ spare hose & coupler in the rear bumper.
http://www.lci1.com/LIP/0127.pdf
Name:	Lippert Sewer Management System.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-26-2011, 03:19 PM   #3
Hob
3 Happy Campers has it down. Listen to what he says about the Rhinoextreme and yes get the plastic support.
Hob
Hob is offline   Reply With Quote
Old 12-26-2011, 03:31 PM   #4
Dallas Texas
TexasBBQ's Avatar
Dave, when you say "a 15’ Rhinoextreme hose in it." do you mean the hose is inside the hard black plastic tube that's after the flex tube?
How is it sealed in the tube? Where did you get it? I didn't find any info on the lci1 wbesite.
2004 Cardinal 33CKT
Old 12-26-2011, 04:38 PM   #5
Correct, the hose goes inside.
The hard plastic tube “the boom” & flex tube make up the Sewer Mgt System.
The system is not available retail. I had my local RV dealer order it from Lippert. Had the dealer install it for about another $100 while the rig was in for inspection. The flex tube section is removable & that’s how you connect the sewer hose itself.
You could fit 20’ in the boom but I already had the 15’ Rhinoextreme hose & a 5’ hunk from a previous damaged hose.
I’ve never found the need to pull out the spare 5’ hose, yet.
Perkasie, PA
2010 Sierra 356RL
Old 12-26-2011, 05:26 PM   #6
jonnys_walkers's Avatar
Sewer Boom
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 12-28-2011, 09:04 AM   #7
Dallas Texas
TexasBBQ's Avatar
Thanks for the info. It sure looks very convenient. Anything that makes "that part" of the TT less of a headache I'm all for it.
2004 Cardinal 33CKT
Old 12-28-2011, 09:56 PM   #8
Terier's Avatar
Amazon.com: Camco 39625 RV Revolution Swivel RV Sewer Kit: This is our first camper with this kind of need so I'd like to get ya'lls opinion. Do I need to get 15 or 20 foot unit? Is there a brand better then another? Does the plastic hose support work ok? Any lessons learned that might help would be appreciated. I don't want any surpprises if you know what I mean.
I have the RhinoFlex 15' hose and really like it. I recently brought an 5' extension hose just in case I come close to not having enough hose again. How much hose you will need will depend on the campground layout. I do use the plastic hose support and besides keeping the hose off the ground I feels it helps with the draining.
I keep my sewer hose inside a long plastic bin in the storage compartment. I do like the ideas that other posters have shared but I opted for cheap and easy for now.
Terier is online now   Reply With Quote
Old 12-28-2011, 10:11 PM   #9
GASPEDDLER's Avatar
I got the Rhino Flex 15 from Amazon and highly recommend it. I keep it in a large rectangular plastic milk crate and place it in the bed of my truck when transporting it. I just make sure to run plenty of grey water through it to Prevent drips in the truck bed. It's long enough for my needs but I also keep an extra 5 feet in my bumper. I would also recommend a clear coupler to place before the hose on your dump valve. Let's you know when your tank is truly clean.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 12-29-2011, 03:08 AM   #10
Dallas Texas
TexasBBQ's Avatar
Gaspeddler - I like the idea on the clear coupler. Does it stay on the pipe from the trailer or does it need to be removed?
2004 Cardinal 33CKT
