06-07-2015, 07:32 PM
Sewer hose seems too long
We camped in our TT for the first time. When emptying the tanks at the dump station, the sewer hose seemed way too long. It is a Rhino brand and was purchased by the previous owners. I'm not sure how long it is. Is it a good idea to have a long hose or is it normally not necessary? I don't know whether to buy a shorter one or find some way to shorten the one I have.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
06-07-2015, 08:01 PM
the Rhino hose can be compressed to about 1/3 its' stretched out length.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
06-07-2015, 08:14 PM
At a dump station it may seem long. You are right at the drain. Stayed at a State park and twenty feet was not enough. Needed two more feet. If you only have one section you may want to get another, just in case. Better to have it than to need it.
2013 Flagstaff 831FKBSS
06-07-2015, 08:43 PM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-08-2015, 09:05 AM
I now have four sewer hoses of various lengths and durability. I tend to use the Rhino extreme sewer hose the most as it has two connections of hose assemblies 10 ft. each. Than I have another brand of two hoses that can be connected to each other and stretched to 40 ft. along with the new low cost hose that the dealer throw in with the sale; still in the bag. I also have various connectors for the full hookup dump pipe to fit the different sewer hoses that I have. I also have two different clear drain connections one is straight the other is a 45 deg angle connection.
When it comes to sewer hoses it seems that you may never have enough at some point in time.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
06-08-2015, 10:12 AM
I'm carrying 30 feet of hose myself. When I am going to end up right next to the dump station I will pull a few feet before or after the dump to ease hose management.
It's something you get used to.
06-08-2015, 10:31 AM
He has it right! Youroo!!
06-08-2015, 12:01 PM
I carry three ten foot hoses and couplers. Over time you will use them all in various combinations. It is also good to have a way to keep a constant slope to the drain. I use sections of plastic gutter and blocks.
06-08-2015, 01:11 PM
I carry 30 feet and a 45 clear coupler of good quality sewer hose. Have had an occasion twice that needed longer than 20 feet. Carry the cheaply that came with the tv for dump station, it compresses to 3 feet or so. In addition carry 50 feet of white water hose and 50 feet of grey hose and a y connector for the supply valve. Always lay out grey hose for grandkids and the campfire in case of an emergency! Otherwise I use grey hose for black tank flush.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
06-08-2015, 01:25 PM
jkoenig24
DON'T cut it! You don't say how long it is extended but, eventually, you will need a long hose. Buy a shorter hose that will couple with the current hose.
06-08-2015, 01:56 PM
Better too long than too short.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
06-08-2015, 02:56 PM
Getting a set of hinged, expandable hose rests can keep the "snake" from killing people and greatly shortening its life plus helps you use only as much length as you need.
06-08-2015, 03:05 PM
For some reason, when I read your post, I heard the voice of Lurch.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
06-08-2015, 03:48 PM
My voice was not quite so low and slow when the RV "lurched" forward when testing the leveling jacks in the driveway. The windshield was at least two feet from the garage roof when starting...........................(oops, can't repeat here).
