Old 03-26-2013, 07:59 PM   #1
Sewer hose support & wye question
For those with 2 grey tanks and use a wye connection, what does a person do for those "slunky" type hose supports. You can't just use say 3 10' slunkies because the slope will be wrong. You *could* I suppose buy a 20' one and cut it in half.
Just wondering what folks do...
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 03-26-2013, 09:49 PM   #2
Fulltime family RVer
I don't use them. So far, the weight of the water has been sufficient to make it thru the sewer hose to the hole- even when the hole was elevated.
ependydad is online now   Reply With Quote
Old 03-26-2013, 10:17 PM   #3
We were at one site last year and the pipe inlet on the ground was really high compared to the TT outlet. I spent a lot of time with the slinkies getting the slope right so the pipe would drain. It was almost horizontal.
I agree, most times just laying on the ground will suffice.
Langley, BC
Old 03-26-2013, 10:28 PM   #4
Don't mess with wyes, plumbed the rear tank into the front 2 and use one hose and lay it on the ground regardless of slope. What little is left in the hose is always grey water and unhooking at the trailer and lifting the hose drains it and then I rinse it with my sewer only Pocket hose.
Old 03-26-2013, 10:34 PM   #5
Rebel702's Avatar
This is from a posting by Herk7769: Attaching drain hose
Quote: "I use a 10 ft section of white plastic rain gutter that I cut into 3 pieces (2x4' and 1x2') to support the drain hose when in hookups and at the dump station to keep everything flowing downhill. I can use my Lego levelers to create pitch. The plastic section of gutter is much cheaper than the commercial products that do the same thing.
I also use a clear plastic 90 degree at the dump outlet (may not apply to your rig) to make sure I can see when I am done when flushing out the tanks. "
You might ask him for some pics to give you ideas.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 03-28-2013, 09:55 AM   #6
I had the same problem using three sewer hoses and a wye. I finally figured out it's best to connect the wye directly to the CG sewer and use one hose for each tank connected to the wye. Much easier to then use my hose supports to get the fall I need.
Tblackmon9599 is offline   Reply With Quote
Old 03-28-2013, 10:33 AM   #7
This is how I do it (minus the hose supports). I connect my wye at the sewer connection and run hoses to each sewer outlet. It's more hose this way (than bring the hoses together at the camper via the wye and then just one hose to the hole in the ground. But, it works for me.
Old 03-28-2013, 10:42 AM   #8
mjones12's Avatar
Great idea. I do the same thing with a commercially made white plastic half-tube that slides out to the length I need. Also in 3 sections. I think it's about 10 feet when fully extended. As you do, I use the leveling blocks to support it at the necessary angle. I like the rain gutter idea and will probably try that if my current one wears out.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 03-28-2013, 11:12 AM   #9
CLASS "A" Senior Member
cfsoistman's Avatar
Same here although occasionally I use a 5ft piece prior to the "Y". Rotating "Y" Sewer Connection - Valterra F02-2030 - Sewer Fittings & Adapters - Camping World
This is the type I use. I have 3-10ft sections and 3-5ft sections of hose so I can connect both no matter where the sewer drain in the ground is located.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-28-2013, 02:25 PM   #10
Owner/Operator
RodeoGeorge's Avatar
I'm fortunate in that the two outlets are only 18" apart.
I use a Rhino Wye, and cut a 5' extension down to the 18" required. No sag, and I can leave both the gray water valves open. Close them a day before dumping.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
