Old 02-13-2016, 03:22 PM   #1
Sewer Hoses
The Camco Rhino seems to be the favorite or most popular ! I purchased the 27RLWS TT. I'd like a clear elbow so that I can monitor my tank when dumping. Would you suggest the 45 degree or 90 degree elbow?
jasanto is offline   Reply With Quote
Old 02-13-2016, 03:29 PM   #2
Ford Idaho's Avatar
I have one of each, the one I use depends on the location of the hole from the FW when parked.
Old 02-13-2016, 03:33 PM   #3
Justice12t's Avatar
x2 I have both and depends on the setup of the CG or DS...
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 02-13-2016, 03:34 PM   #4
Blaster 84's Avatar
If your using the elbow where it comes off the RV I believe a 45 would be best. Less resistance to the flow. If you want it just before it enters the sewer I would also go with a 45 on its side before it goes into the 90 going into the sewer. I'd lay on its side to keep the fluid from having to go uphill as much as possible before entering the sewer I hope that makes since. I've tried it both ways and have settled on the first option.
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is offline   Reply With Quote
Old 02-13-2016, 03:39 PM   #5
Homebrew's Avatar
45deg with hose connection for hose connection , makes rinsing hose easy.
Name:   ImageUploadedByForest River Forums1455399474.336748.jpg
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 02-13-2016, 09:49 PM   #6
Agree with others have both 45 and 90, also have a straight. Have never had to use the 90.
Rich5117 is offline   Reply With Quote
Old 02-13-2016, 10:03 PM   #7
WFD
Yes the Rhino is well worth the money, very durable, plus folds down to a nice manageable size to store. You may want to invest in 1 or 2 5ft extension pieces as well. Have only needed them a couple times but some campsites have the sewer drain set far enough back making the regular 15 ft just a tad short.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-14-2016, 07:16 AM   #8
cpaulsen's Avatar
Have both also depending on the sewer location. Rhino is a good hose.....I also carry the Blueline too,
cpaulsen is offline   Reply With Quote
Old 02-14-2016, 08:01 AM   #9
Canadian Member
itat's Avatar
I have a straight and a 45 deg. I prefer the 45 deg. fitting (it's a Rhino fitting) but it leaked the first time I used it so I haven't used it since. I wouldn't bother with a 90 deg. bend. Always use it at the RV tank outlet, not at the other end.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-14-2016, 08:14 AM   #10
Ford Idaho's Avatar
Could the rubber seal be missing or not in place correctly?
