05-16-2018, 05:21 AM
Shower drain Leak
Got out the 2016 Coachmen Mirada and the shower drain in leaking. The nut at the end of the trap is broke. This nut attaches the black pipe to the trap. Has anyone replaced this, there doesn't appear to be enough to cut the pip and add new. Not a very good design if you have a problem. Looking for suggestions to repair. Any help would be greatly appreciated. Thanks
Chris and Pam Travis
Massillon, Oh
2016 Coachmen Mirada 35BH
Dog-- Brodie (English Labrador)
Cat--Macy
Bearded dragon- BRUTUS
05-16-2018, 05:58 AM
Can you post a picture? A trap has two ends. Which end is the nut cracked on? If it is like all of the other shower p-traps I have seen on RVs, all you need is another 1-1/2” slip joint nut. It doesn’t matter if the nut is metal, black or white — any of them will work.
Bruce
05-16-2018, 06:06 AM
Bruce
It's the nut on the right after the trap. How do you replace the nut? I have it apart, it seems like the piece is glued in. I will post a picture this evening.
Massillon, Oh
Cat--Macy
05-16-2018, 06:13 AM
If it is glued on and you have no easy way of taking it apart, you can do a rig fix on it by putting a hose clamp around the nut to bring the split back together, then tighten the nut back onto the trap. The trap and nuts are made of polypropylene — not ABS or PVC, so you can’t try to glue it because it won’t work.
A picture would really help.
Bruce
05-16-2018, 06:18 AM
Bruce
Ok I'll get a picture tonight. The nut is actually broke out on the flat part (were the washer would seal) not split in half if that makes sense.
Massillon, Oh
Cat--Macy
05-16-2018, 06:19 AM
Makes sense. It was over-tightened.
Bruce
05-16-2018, 06:23 AM
Bruce
I appreciate the help
Massillon, Oh
Cat--Macy
05-16-2018, 06:24 AM
You’re welcome. I will check back later to see if you posted a picture.
Bruce
05-16-2018, 04:04 PM
Bruce
Here's the issue.
Massillon, Oh
Cat--Macy
05-16-2018, 04:59 PM
Massillon, Oh
Cat--Macy
05-16-2018, 05:01 PM
Not sure why it doubled the pics up, I apologize. Have a good day
Massillon, Oh
Cat--Macy
05-16-2018, 05:38 PM
It's been running for an hour, no leaks. [emoji1]
Massillon, Oh
Cat--Macy
05-16-2018, 06:55 PM
Where is the trap?
Bruce
05-17-2018, 03:57 AM
Never mind. I took a closer look and see what you did. If it doesn’t leak, go with it.
Bruce
