Old 03-09-2014, 12:45 PM   #1
Exclamation Shower drain not attached
Our 2014 40 CRS was just delivered. I took a shower the next day and there was water all over the bathroom floor and water on the ground outside. Turns out the pipe from the shower drain was not attached to the main pipe going to the holding tanks. Maybe came loose during delivery. The main drain pipe has a very small lip that the shower drain pipe has to attach to. There are no threads on the main pipe. Any suggestions?
Take a Break is offline   Reply With Quote
Old 03-09-2014, 12:59 PM   #2
Denver, CO
garbonz's Avatar
Warranty It may not be that easy a fix. Dealer should be able to do it tho
2017 Fuse 23T
Old 03-09-2014, 01:18 PM   #3
Shower drain not attached.
The dealer suggested we call someone local but we need someone who knows about RV plumbing.
Old 03-09-2014, 01:24 PM   #4
Ford Idaho's Avatar
The pipe used in an RV is used in a stick house, all you need is the pipe to be dry and the right type of glue.
drain, show, shower
