07-13-2018, 09:34 AM
Shower drip-replace or repair??
We recently bought a 'new' 2017 Salem Cruise lite 175RD. Shower developed a 'drip' (actually a slow stream). I'm under warranty, but the dealer is over 3 hrs away. I've fixed drippy faucets at home (replacing a little 'O' ring), but in searching the web, it seems that on my trailer it may involve a total faucet replacement (which appears easy though)
So, quick question, are those faucets repairable, or do they indeed require total replacement? thanks!
07-13-2018, 09:44 AM
Replace.
07-13-2018, 10:53 AM
X2. Replace with an Oxygenics shower head. Ours has operated great for years.
07-13-2018, 10:55 AM
It's better to replace it with a better quality model. It should be a standard 4" spacing faucet. I replaced ours because I didn't like the way the handles operated.
Gotta go campin!
07-13-2018, 11:25 AM
Do not even call the Dealer...
fix it right (and you know that it will be right) with a good substitute. Do not replace type with type... get a better one. (and think about replacing ALL of the faucets and have shut off valves to each one..)
Brother Les
07-13-2018, 11:55 AM
Replace with better faucet. The OE stuff is so cheaply made repairing will just become a pastime.
07-13-2018, 11:58 AM
Thanks for the comments everyone!
I've decided to replace with a better faucet (of course now I have to decide what is 'better' LOL)
Thanks again
07-13-2018, 12:15 PM
Is this water coming out due to shutting off at the valve on the spray head or a the actual faucet knobs. If only at the spray head, this is normal.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
07-13-2018, 01:12 PM
I shut off at the faucet knobs, not the spray head (well, ok, that's also turned to off, but I know those drip anyhow)
I did use the shower once on our first trip with the trailer a bit over a month ago and everything was fine. Several trips since, and no problem, but this trip, the dripping started. I did check and the knobs are securely turned to 'off' and hadn't worked themselve open at all
07-13-2018, 01:46 PM
Carknocker Family
New trailer? Probably has construction debris in the valves. Take it apart and get the sawdust out. Had to do this on kitchen faucet
07-14-2018, 08:12 AM
In answer to your question,,, many RV Faucets are not repairable,,, unless you can order new stems,,, most do not have faucet washers,,, they are about 99% Chinese plastic !!!
