Old 10-05-2018, 08:03 PM   #1
Shower Faucet
Anyone have a 2006 Wildcat that can tell me about replacing the shower faucet? Cold handle broke on our trip. Could not locate shutoff for just shower. Grrrrr. Couldnít just buy replacement handle so had to get complete new faucet. Need info on accessing back side of shower wall for faucet removal. Thanks if anyone can help!
Shoney1 is offline   Reply With Quote
Old 10-06-2018, 06:32 AM   #2
cpaulsen's Avatar
When I had my 07 Wildcat.........access to the shower valve was outside the shower up high. A round cap inset in the side.....stick your finger in the slots in that plug and turn it.
cpaulsen is offline   Reply With Quote
Old 10-06-2018, 07:08 AM   #3
cavie's Avatar
There is no independent shut off valve to locate. Is you valve surface mounted (as mine is ) or flush like one you may have at home. A picture would help. The surface mount has two screws visible on the front of the valve. If flush mount there would be an access panel of the backside of the wall.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 10-07-2018, 05:57 AM   #4
Sure do thank you. New one all installed. Appreciate you input.
faucet, show, shower
