Old 10-09-2012, 07:40 PM   #1
crushor's Avatar
Shower Faucet Seal Replacement prior to winterizing
Well, on our last outing after pulling into campsite, we found that we had a fresh water leak that I traced to the shower. Not sure how this came to show itself, as we travel with the pump off, but I spent quite some time tracking it down to the rear of the faucet assembly where the hot water comes into the faucet. The assembly is still apart as I have asked my wife, who works for the trailer place that we bought the trailer from, if she would pick up new seals. The one that failed was a white seal. She has been told that not only should these seals have NOT failed, that they cannot be replaced, as they can not get replacements. She was told to replace the entire faucet assembly. If this is correct, I have no problem with it as these faucets are quite inexpensive, otherwise, where does one get these seals? Thanks. As usual, I certainly appreciate the input.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 10-09-2012, 08:53 PM   #2
VinceU's Avatar
Not sure if it piping nut connection to the fixture or the valve bonnet (stem and housing ) that screw into the fixture. Not sure if o'ring or flat gasket however there is always Permatex "form a gasket" just a silicon tube material you can squeeze into the retaining groove and tighten against it.
Old 10-09-2012, 09:12 PM   #3
john I
johnemt's Avatar
If it where me i would replace the whole fauset. these rv fauset generaly are pretty cheap and do not responed well to repairs
John I
2012 Columbus 365RL
2012 Dodge Ram 3500 6.7 cummins
1963 5'2" wife Sheri
johnemt is offline   Reply With Quote
Old 10-09-2012, 09:13 PM   #4
Fire Instructor's Avatar
On my outside shower the gasket was fine. It was the screw-bonnet that had cracked. About a $10 repair. Found the part that I needed on a peg-board at Camping World.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-10-2012, 05:46 AM   #5
crushor's Avatar
VinceU, it is the seal at the pipe fitting on the rear of the shower assy. There was a white seal there. As I don't want this issue to arise again, as Johnemt mentioned this fixture isn't repair friendly I am thinking that I might trim about 1/2" off both lines, install new fittings as well as a new shower assy. Heck when I took the shower head off I saw that the head had a crack in it. So here comes the oxygenics (sp?) shower head...thanks again guys.
Old 10-10-2012, 09:05 AM   #6
VinceU's Avatar
Good choice! wasn' freeze damage, was it?
Old 10-10-2012, 09:26 AM   #7
crushor's Avatar
Don't believe it was freeze damage. I know that it was winterized last year before we purchased it. When we brought it back to the dealer they went through everything and ended up replacing the outside shower (complete) as they found it cracked. However other than that everything seemed alright. I do have another plumbing question, however I need to upload pics... Winterizing though seemed like it was done thoroughly.
Old 10-10-2012, 12:03 PM   #8
these cheap faucets seem to crack (in the back) very often, I have replaced inside shower, outside shower, kitchen faucet, and lastly bathroom faucet... same on my old unit. ;-) I replaced mine with an "upgraded" style that appears to be of much higher quality!
2006 Lincoln Mark LT/2011 Lincoln MKZ/2010 Kia Soul Sport
2008 FR Salem LA 292FBDS
Days camped 2010: 365
2011: 365
2012: 365
Fulltimers
viperjpm2 is offline   Reply With Quote
Old 10-10-2012, 03:41 PM   #9
crushor's Avatar
Thanks Viper...in trying to find this "upgraded" style, is this something that CW or Amazon carry. I was looking at both sites last night and found several selections and unless half-zeimers is kicking in I don't remember anything being listed as such. Of course I could revisit those sites.
Old 10-10-2012, 05:30 PM   #10
Crushor - I try to stay out of CW for fear of maxing out my credit cards! I tend to buy EVERYTHING online, mostly on Ebay but occasionally on Amazon as well. I attached some pictures of what came with my TT and what I installed afterwards, the original faucets had really unattractive tinted knob style handles (circa 1985) the newer ones have "lever" type handles, the shower and bathroom faucet match and are made by Empire Brass Company (pics attached)
here are the current links on Ebay
RV Mobile Home Marine Parts. Bathroom Sink Faucet Lav White Finish | eBay
and
4" Shower Faucet RV Marine White w/ easy to use Tea Pot handles Free Shipping! | eBay
in my kitchen I installed a Moen residential style faucet, when I get home tonight I will snap a pic! its a really neat setup, I wanted a side sprayer but my TT sink only has 3 holes, with this setup the third hole is utilized by a sprayer... yes I could have gotten one that the spigot itself pulls out but I found them to be rather expensive and bulky looking in the TT
ID:	20494   Click image for larger version
ID:	20495   Click image for larger version
ID:	20496   Click image for larger version
2011: 365
2012: 365
Fulltimers
faucet
