Old 03-04-2013, 12:28 PM   #11
Originally Posted by lindy View Post
BigTJohn, did you caulk the seam between the shower wall and the floor pan. My dealer said do not caulk this seam as it was left uncaulked so that is any moisture got behind the shower wall it has a way to escape, and that the shower pan extended up about 2" behind the shower wall.
X2
Old 03-04-2013, 04:53 PM   #12
BigTJohn's Avatar
Yes. I caulked all seams. Used marine sealant 5200 which also bonds the pan and walls together. There is enough air circulation to dry any minor moisture under the pan or behind the wall. I check via the pan inspection plate. If there is anything, I can take the door trim off and check from there as well as get air circulating using a shop vac.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-04-2013, 09:07 PM   #13
I called Rockwood plant and warranty guy there said caulk all seams at pan. He said back lip only went up about 1/4 to 3/8 of an inch.. Not very high. Wonder which tech is correct. I now I have double caulked and found no leaks. Will let y'all know how it goes after 3 day trip this weekend . Have a good week
Hawg Hunter is offline   Reply With Quote
