Old 09-18-2016, 03:47 PM   #1
Shower pan
Hi,
We have a 2015 Flagstaff with a cracked shower pan. It's made of recycled plastics and it's super thin and flimsy. No warranty because we are second owners. From my perspective, if I have to replace it, I would like to go with fiberglass, If I can find one. Any ideas? ]Does anyone know if this can possibly be repaired. The cracks is very straight and about 4" long.
bruno4321 is offline   Reply With Quote
Old 09-18-2016, 03:54 PM   #2
Could you post a Pic of the "Under side" through the Inspection door? thanks Youroo!!
Old 09-19-2016, 07:36 AM   #3
here's a pic
Old 09-19-2016, 07:37 AM   #4
upside-down, lol
Old 09-19-2016, 07:39 AM   #5
manufacturing info
Old 09-19-2016, 08:04 AM   #6
jeff
jeff64's Avatar
It's probably ABS which I think you can find some specialty epoxy or adhesives to do it but, probably not in place and it wouldn't be pretty. The only other thing that comes to mind would be a gusset of aluminum or stainless (patch) to reinforce and pop rivet it in. It will either work or you can guess the alternative. If it were me, I'd look for the new pan that fit and and foam it in with Great Stuff since you know where the weak spots showed up. My shower ( looks like yours)had significant flex around the drain area floor, which I took care of last year, knock on wood, been good so far. Drain setup kind of looked like the photos in previous post on the thread. Just my $ .02 worth. Good luck, clue us in how you resolved issue.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-19-2016, 08:11 AM   #7
OK now are the cracks located in the "Unsupported area" of the Pan? Drain hole area? Is/Was the pan floor like a "Trampoline"? Are the cracks located where there is NO plywood/styrofoam to support it? Youroo!!
Old 09-19-2016, 09:31 AM   #8
Jlreeves's Avatar
In our old class C we had a sagging shower pan. I drilled a few small holes in side of pan and used Great Stuff expanding foam. I did put a small PT barrier around drain and just let foam fill in area. Used a fiberglass repair kit to repair holes and crack. Added the fiberglass tape to stress crack area then covered with fiberglass patch compound. Painted entire pan with almond colored epoxy appliance spray paint. Was still in great shape 6 years later when we sold it.
2017 PrimeTime Crusader 315RST 5th Wheel
2014 Chevrolet Silverado 2500 HD
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
Jlreeves is offline   Reply With Quote
Old 09-19-2016, 09:46 AM   #9
there is not enough support around the drain.. i can see, but where it's cracked , not visible from accessing panel. but it has to be a support issue. It broke with my wife she is about 109 lbs. maybe a little flimsy but not something I felt. The material is just not up to the task..
Old 09-19-2016, 09:58 AM   #10
Iwannacamp's Avatar
I guess everyone/most should check out the floor pan reinforcement on their shower...
Adding to memory to check
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
show, shower
