In most, the shower floor is elevated, and there will a trap door somewhere. May be a panel screwed down, may be a twist look opening. Should be withing access of the drain, because you have to use the opening to disconnect the drain, in order to remove the shower floor pan.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
