Old 09-25-2014, 08:40 PM   #1
Mark Burkholz's Avatar
Shower stall leak
2014 Minilite. Shower stall leaks behind the toilet. I'm thinking about running a caulk bead to direct water back towards the shower base. Anyone have any suggestions for this? Thanks in advance!
Mark Burkholz is offline   Reply With Quote
Old 09-25-2014, 08:46 PM   #2
PSUFan1's Avatar
What model mini lite
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 09-25-2014, 08:51 PM   #3
2106
Old 09-29-2014, 06:18 PM   #4
PSUFan1's Avatar
Do a search on this forum and you will find some have used a piece of plexi glass on the angle showers to prevent leaking.
Old 09-29-2014, 06:53 PM   #5
Thanks for the tip, I'll check it out!
Old 10-04-2014, 05:46 AM   #6
I had the same problem. I ran a tall caulk bead near the toilet like you're talking and one against the sink vanity and no more leaks.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 10-04-2014, 06:19 AM   #7
Thanks, that's what I've done. I think it should work out.
Old 11-30-2014, 07:36 AM   #8
We have an FR3 2015 30DS, and we have showered only 2 times and water was all over the floor, at least a quart or more after each use? What can I do not to void warranty issues? Thank you! Mike
schrodoc is offline   Reply With Quote
Old 11-30-2014, 07:38 AM   #9
Sorry... NOT void warranty!
Old 11-30-2014, 07:40 AM   #10
I was thinking of caulking along floor by shower but that would only trap the water and rot the floor under the shower correct?
leak, show, shower
