Old 11-03-2018, 08:00 PM   #1
Shower Surround turning Yellow
The upper part of the shower surround in our 2012 Flagstaff Microlite 25DS is turning yellow from the sun shining through the skylight overhead. Is there any way to remove the yellow short of painting the surround or replacing it? (I will be covering the skylight in the future to stop further yellowing)
rwhmtnfolks is offline   Reply With Quote
Old 11-04-2018, 09:45 AM   #2
SeaDog's Avatar
The yellowing is caused by the chemicals leaching out of the plastic from exposure to the sone and time. I think painting is the only way to cover that yellow. Consider making a contrasting strip around the surround if you paint to cover the yellow. I'm sure other Frogs will know of some other solution.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-04-2018, 10:24 AM   #3
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Sad to hear. Thanks for sharing your problem. I will have to get a cover for my skylight or add an internal shade. Some of the others on here have made a nice cover out of perforated metal. I keep my rig under a large covered structure and out of the sun, so I don’t think its a problem until we head out more often for long term camping.
How long did it take for yours to fade?
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 11-04-2018, 12:37 PM   #4
NMWildcat's Avatar
Every RV with that type of plastic used for anything, discolors quickly. Especially in the Southwest. We always use some type of film or sunscreen on all skylights. Shower discolors within a year anyway. Doesn't really bother us. Just the nature of the beast. Just don't understand why the manufacturers insist on using these type of plastics. Well I do, $$$$$.
Some friends didn't like their discolored shower, so they painted with plastic paint. Looked great for about a year, then started coming off. Yuck. So we just live with the slightly yellow color
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 11-04-2018, 12:42 PM   #5
Commercial Member
Are you sure it is yellowing from the sinlight or are you in a location with a lot of sulfer or iron in the water?
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 11-06-2018, 10:04 AM   #6
Thanks for your comments and suggestions. The trailer is 6 1/2 years old, stored outdoors in a dry, sunny climate. Started yellowing last fall and got progressively worse this summer. Have sprayed the affected areas with hydrogen peroxide to see if that will bleach it out, but not holding out much hope. Guess we'll live with it though it bugs me no end to see it. I'll post an update if I find a solution other than painting.
Old 11-06-2018, 10:18 AM   #7
I had a cheap surround in a bathroom in our house. There was a window in the bathroom and within 3-4 years we had a perfect diagonal stripe across one panel of the surround that matched the sunlight coming in thru the window. RV's use that same cheap surround that I used.
TheWolfPaq82 is online now   Reply With Quote
show, shower
