2 suggestions,
1) do you have a removable panel at/on the bottom 'wall" of the tub? If so, can you reach the cracked place from under the tub? If so, read up on how to do fiberglassing using cloth and resin. By fiberglassing under the tub along the backside of the crack, you can seal and reinforce the tub so it'll not leak and be serviceable. It would also help to stabilize the bottom of the tub under the crack with, for example, a block of wood which will reduce/eliminate flexing in that area.
2) I know your unit is 10 years old, however, a phone call to the manufacturer will answer the question as to the availability of a original or replacement tub.
Good luck, Ron
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
