Old 02-08-2016, 02:01 PM   #1
Shower valve connection
My shower hose attaches to the TOP of the wall mounted valve assembly. This places stress on the poor little hose (any of them) as it bends downward. I'm assuming the valve assembly is attached to the pex lines like the lav. and sink are and can be simply removed and turned over to hang the hose downward.
Question is: is there a secret valve inside that doing this will cause a problem?
Due to difference in DW and I in altitude, I added a wall mounted adjustable shower holder and will be going with another hose anyway.
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 02-08-2016, 02:18 PM   #2
"Vacuum breaker" would be the secret part I'm concerned about. I see both styles for sale, so, why would FR use one to collapse the hose?
Old 02-08-2016, 02:21 PM   #3
It is mounted "Upside Down" install it with the outlet on the bottom and also put a S/O valve on it,make both of you happy! Youroo!!
Old 02-08-2016, 02:25 PM   #4
Vacuum breaker has No bearing on the Shower,just BTR! Youroo!!
Old 02-08-2016, 02:38 PM   #5
Amish Plumber
Amish built it upside down? No wonder the awning won't extend!
show, shower
