Old 03-26-2016, 06:02 AM   #11
nomad297's Avatar
Originally Posted by Platokidd View Post
Think this is what the op has in the shower?
2016 Cherokee Grey Wolf 26DBH Limited
Yes. It also works as a great vapor barrier for the rest of the camper. No humidity will make its way into the inner walls.
Bruce
nomad297 is online now   Reply With Quote
Old 03-26-2016, 07:58 AM   #12
What do guys you think about the trim around the tub and the screws? I have a similar bath and there is no sealant around the trim or on the screws. I notice this after are first trip when several stripped screws backed out. My last two campers did not have any screws or trim where the walls meet the tub.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 03-28-2016, 06:20 PM   #13
Platokidd's Avatar
I have not seen this type of shower in any unit.
Hmm.. the wall is enough to raise an eyebrow on it own. The trim does look like it could be a water catch? Think I would remove the trim to have a look behind it. See if any water is getting past the trim and if so where it goes. Think I would also caulk the screw holes, add a couple of toothpicks and re-screw.
Maybe someone could post better pics of this wall and trim.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-29-2016, 09:03 AM   #14
Sorry for not responding. Just got back from Campin'! in a cell hole.
Will give proper response later.
Family of six, camping in a Grey Wolf 26DBH LTD pushing a 2010 Armada via 10k/1k HaulMaster WDH stopped by a Prodigy P2 brake controller
Tug: 2010 2wd Nissan Armada Titanium with tow package.
Specs: Max Trailer Weight 9,100, Tongue Load: 910, GCWR: 15,100, GVWR: 7,150, Payload: 1,592
DadOfTwo is offline   Reply With Quote
Old 03-29-2016, 01:29 PM   #15
OK, added info to my profile, as requested.
But still no pix.
The wallboard in the shower is the same throughout the rest of the camper, but is caulked at the corners, and around the tub and fixtures.
Old 03-29-2016, 01:34 PM   #16
Our first trailer was like that. We showered in it 100+ times and never had an issue. I never liked it though.
I've seen people get plastic sheets and install them on the walls.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
Old 03-29-2016, 02:17 PM   #17
The first time I noticed the showers without the fiberglass surrounds were in Jayco's a couple of years ago at a show. I think it was the Jay Feather SLX line. Maybe the surround was optional as I know their water heaters are or used to be.
Evidently the vinyl paper covered luan plywood is waterproof enough. I am not sure if I would trust it long term if using the shower a lot, I'd add a surround or at least throw up some FRP around it. IMO the only purpose it serves is eliminating the cost of installing a $200 surround, sort of like installing entry doors that do not have windows. I always thought that was dumb and looked like hell. Maybe they could use the interior panels on the outside sidewall and roof if they're that waterproof?
Mr Havercamp is offline   Reply With Quote
Old 03-29-2016, 02:38 PM   #18
Bluepill's Avatar
Possibly the "new style" construction is a weight saver as well as a cost saver for FR.
In any multi-piece shower/bath assembly, regular inspection of all joints is an absolute must. Everything must be properly caulked and sealed. It only takes a small failure to start serious damage to other areas.
2008 Itasca Meridian 37H
roo, roof, show, shower, water
