Old 04-29-2012, 07:34 PM   #1
crazycampers's Avatar
shower water
ok so took the new TT out for first time this weekend and everything was great ecept for water pressure in shower ..it was barely a trickel ,,read somewhere that its usually just the cheaper heads that come on them will an upgraded shower help or is there another solutation? btw the camper is a surveyor sv 302.. thanks
crazycampers is offline   Reply With Quote
Old 04-29-2012, 07:45 PM   #2
Did you have it hooked up to city water line?
Did you have the water pump on if you were using water from your storage tank?
Have you ever unscrewed the shower head to see if the pressure increases and you have a clog in the head?
Have you inspected your water filter to see if it was clogged and needs repalcing?
If you can answer a few questions to see what you have do will help others to answer your question.
Old 04-29-2012, 07:58 PM   #3
Herk7769's Avatar
I replaced my shower head with this type. It works great even with low water pressure from the on board pump. I broke the white trickle valve the day after I installed it. A quick trip to the hardware store got me back in action. I want to add a smaller valve, but this one may not be pretty, it works.
Amazon.com: Oxygenics Body Spa Handheld Shower Kit, Brushed Nickel: Home Improvement
Name:	10 July 2011 048.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-29-2012, 08:00 PM   #4
Good stuff Herk I installed the same ball valve about two weeks ago as you said certainly not pretty but it shuts the water off completely just like I wanted.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-29-2012, 08:39 PM   #5
J. Parham
snjparham's Avatar
The Oxygenics shower head is awesome. Almost like your home shower.
2011 8528BHSS
2013 Silverado 2500HD 6.6L
Nights Camped in 2011: 32
Nights Camped in 2012: 85
snjparham is offline   Reply With Quote
Old 04-30-2012, 01:52 AM   #6
Namchief's Avatar
I agree Oxygenics shower head is the way to go!!!
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 05-01-2012, 08:12 PM   #7
thanks thats what i was leaning towards just wanted some input
Old 05-01-2012, 08:23 PM   #8
The ONLY drawback is they don't shut off completely.
Old 05-01-2012, 10:05 PM   #9
alphadog99's Avatar
We had pressure issues in our Rockwood even after installing an Oxygenics head. I took the hose that came with the Oxygenics off the faucet end and found a washer that was supposed to have had the center punched out and removed. It had been punched, but the center part was still in place except for one edge. I took the center part out, reattached the hose, and man what a difference! Not sure if the washer came with the Oxygenics hose or the factory hose, but it was certainly restricting water pressure.
2016 Wildcat 29RLX
2011 GMC Sierra 2500HD Duramax CC
Banks tuner, airbox and filter
Rancho RS9000XL's and Firestone airbags
Pullrite Superglide 18k hitch
alphadog99 is offline   Reply With Quote
Old 05-01-2012, 10:12 PM   #10
That washer is a designed, govt required flow restrictor and back flow preventer. I usually just remove the flapper and enlarge the hole.
