Old 03-29-2016, 10:14 AM   #1
SeaDog's Avatar
Shurflo 4008 cut in pressure
First question
I have searched and cannot find the cut in pressure for a Shuffle 4008. The cut out pressure is 55psi. I know the manual says an accumulator is not needed however I have a water works 2 gal and want to install it.
Second question
If you were installing a accumulator in a system with a Shuffle 4008 would you increase the bypass pressure setting on the pump?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
pressure
