Old 11-02-2013, 12:13 PM   #1
Scottsmenn's Avatar
Shurflo Water Pump
Trying to winterize today, I am stuck on trying to figure out how to add the antifreeze to the intake side of the pump. Nothing to screw off to hook my hose up to as far as I can see.
2013 Forest River Grey Wolf
2004 Ford Expedition
Camping Days 2013: 6
Scottsmenn is offline   Reply With Quote
Old 11-02-2013, 02:25 PM   #2
Please tell us what RV you have. It's usually best to put this information into your Profile and/or Signature (UserCP in the green bar in the top part of the screen).
If your RV doesn't already have one, they make a winterization kit for that purpose. The only other alternative is to pour the pink stuff into the fresh water tank (but it's going to take a lot of it).
Old 11-02-2013, 02:30 PM   #3
Herk7769's Avatar
Attachment 42194
Yea, they kinda boned ya by not putting a threaded fitting on the intake filter.
You will need to cut the hose between the screened intake filter and the fresh water tank and install a winterizing valve and hose.
Camco RV Pump Converter Winterizing Kit - Mills Fleet Farm
You will also need two NPT to hose barbs like these (depending on your hose size).
http://www.ebay.com/itm/like/190688044228?lpid=82
HAM CALLSIGN - KC3FFW
Old 11-02-2013, 02:44 PM   #4
Scottsmenn's Avatar
Sorry, I thought I added that information already. Thanks for the help. I figured it out finally. I sure appreciate all the help on this forum.
Old 11-02-2013, 02:45 PM   #5
Ford Idaho's Avatar
So what was it you needed to do/know, in case someone else needs to know.
Old 11-02-2013, 02:59 PM   #6
Still not there I'm afraid. Be sure to use the "Save Changes" button at the bottom when you're finished.
Old 11-02-2013, 05:56 PM   #7
Scottsmenn's Avatar
I figured out how to loosen the clamp a little on the inlet hose, that allowed me to spin off the whole filter piece. I was then able to hook my hose fitting right onto the pump. I guess I am screwed if there is any water left in the filter itself.
