Old 02-21-2016, 08:32 PM   #1
Freds342's Avatar
Shurflo Water pump switch
I'm an Electrical Engineer, and have a bad pressure regulator switch on my Shurflo water pump.
I looked all over the net to find the switch, but could only find the complete head assembly for over thirty bucks!
I found the (almost) same switch at Allied Electronics for less than two bucks!
The "almost " part is that it has a normally open contact that can easily be broken off with a pair of pliers.
This switch has a rating of twice the original, and fits perfectly!
Allied P/N: 7120159.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 02-21-2016, 08:51 PM   #2
Too old to be too smart
SpringerPop's Avatar
Would you check that Allied part number again?
When I input that number at Allied's website, it returns:
No results found for "7120159"
Thanks.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 02-24-2016, 02:59 PM   #3
Freds342's Avatar
Okay, Rockwell P/N: V7-1V19E9.
Sometimes Allied doesn't recognize their own "house" numbers!
Old 02-28-2016, 12:08 AM   #4
Ahhhh, a "microswitch". I wasn't aware that they had current ratings available that high.
http://www.alliedelec.com/honeywell-v7-1v19e9/70120159/
Good find! Thanks for sharing!
I'll get one, too.
Pop
pump, water, water pump
