Old 11-28-2018, 02:49 PM   #1
scottshoe's Avatar
Shurflow pump
Model 4008, having to replace my pump for the 2nd time in a year & a half. Just quits pumping water. Anyone have issues with theirs?? No leaks in system. Seems to run fine. May have run it for a short time dry.
scottshoe is offline   Reply With Quote
Old 11-28-2018, 04:00 PM   #2
Head Rambler
Have you taken them apart to see if there was something holding the check valves open, or stuck in the diaphragm area? That's usually why the just quit pumping.
Gotta go campin!
Old 11-28-2018, 04:50 PM   #3
cavie's Avatar
Amazon is your friend. Sureflow pumps are very serviceable. Repair kits are available. You may just have a stuck check valve. Take it apart and clean it.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 11-28-2018, 05:53 PM   #4
I had this problem. I replaced the pump, but kept the old one. I took it apart, saw nothing unusual. When I reassembled it and tested it at the kitchen sink, it pumped fine. I keep it as a spare.
AbdRahim is offline   Reply With Quote
Old 11-28-2018, 06:11 PM   #5
By all means repair rather than buy new. If the motor runs it's definitely just something stuck in a valve or a leak in the diaphragm.
Not a bad idea to have a repair kit on hand. Not terribly expensive and consider a replacement check valve as well.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-28-2018, 07:06 PM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Repair, don't replace.
Order two repair kits and keep one as a spare.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
pump
