Old 03-23-2018, 04:00 PM   #1
Shutting off water to Washer/Dryer taps
I have a 2016 Sierra 377FLIK 5th wheel with Washer/Dryer connections in the back closet in the bedroom. We don't have a Washer/Dryer, but still need to winterize/dewinterize the plumbing at each change in seasons. I'd like to install shutoff valves on hot/cold pipes (PEX) to washer/dryer. Has anyone done this? What does the plumbing look like inside coroplast sheeting?
2016 FR Sierra 377FLIK
2016 GMC Sierra 2500HD Diesel
ktvaughan is offline   Reply With Quote
Old 03-23-2018, 08:51 PM   #2
we have a similar situation with washer / dryer prep in the rear bedroom. I have not installed a shut off valve in the lines. there is a shutoff valve on both the hot and cold line in the washer / dryer closet. to make winterizing these lines easier I built a short hose with a barbed female garden hose fitting inserted into about a 3 foot section of clear vinyl tubing held with a plumbing clamp. I screw this hose onto the male output of a line and I place the other end of the hose down the washer drain pipe. then I can open the existing shutoff valve to winterize / dewinterize with no mess as the water / antifreeze just runs over to the drain pipe. yes it take more antifreeze to fill these plumbing lines, but it's a small cost compared to the effort it looks like it would take to open up the coroplast and work underneath the trailer.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 03-24-2018, 09:42 AM   #3
That's my solution now (tubing at washer connections), but I was interested in something eazier. I see your poiint about cost.
Old 04-08-2018, 08:35 PM   #4
I do have access to the plumbing in my basement but am concerned about putting a valve with a short stub that will not drain when I blow out the lines.
When blowing out the lines with air, I put a rag over the faucet and open it up to blow out the water.
When dewinterizing, i put a rag over the faucet and open it until water comes out (bleeding air from the line)
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
water
