Old 06-30-2014, 10:18 PM   #1
LKicklight's Avatar
Single Lever Sin Faucet
On top of all that has happened since coming to Alaska, now the gally faucet is leaking around its base. Took it apart, no broken seals, cleaned it, greased it up well, put it back together, lasted one day, now leaking once more from around its base a sink level...Home Depot here we come tomorrow in Anchorage, AK....when will it stop!!
kickstere
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 07-01-2014, 09:06 AM   #2
WFD
So are you thinking of replacing it with a residential faucet? Or are you hitting Home Depot for parts or supplies to fix what you have?
Can any of these RV faucets be replaced with regular residential faucets? Never examined it, but I suppose there is nothing different to how the plumbing connects to the actual faucet, be it residential or RV specific.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-01-2014, 09:28 AM   #3
Our unit had the (Plastic pullout/kitchen sink faucet),what a piece of junk! Replaced with a (Highrise ) faucet from HD. We replaced the plastic one in the Bath also with a (Single Lever) also from HD. Youroo!!
Old 07-01-2014, 09:35 AM   #4
I've noticed the faucet that came with our RV is lacking in the pressure and flow rate. Does going to the residential faucet help in this area? If it does I just might move up my plans on replacing ours.
keith_h is offline   Reply With Quote
Old 07-01-2014, 10:04 AM   #5
SKnight's Avatar
Note to self, if ever a trip to Alaska is made pack plenty of tools!
Hope things smooth out from here!
Old 07-01-2014, 10:42 AM   #6
It depends on how it is restricted (Screens/orifices) as to flow GPM. Now pressure is dependent on your incoming setting of your pressure regulator while on (City) water,and your pump setting while on (Stored Water). We have a (5gal) accumulator tank that eliminates the (Pump pulsation) also! Youroo!!
Old 07-01-2014, 10:48 AM   #7
Crusader's Avatar
kickstere
I’m convinced ……… If your in a crusader, it will never stop !!
Thank god for my seven year extended warranty !!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 07-01-2014, 11:05 AM   #8
Ford Idaho's Avatar
Talking
WAIT!!!
Stop the thread, people keep one for seven years?
How does one avoid the upgrade bug that long....
Old 07-01-2014, 11:09 AM   #9
Crusader's Avatar
Originally Posted by Ford Idaho View Post
WAIT!!!
The “upgrade bug” is a tough fight !! The warranty makes for a good selling feature.
Old 07-01-2014, 11:11 AM   #10
Plenty of water pressure while hooked up to house. I just noticed the faucet than came in the TT doesn't have much flow and when I talked to Palomino they said they are all like that. Without the faucet attached the main line seems to be ok. I plan to replace it at some point but if a residential would make a marked improvement then I would push some of the other improvement projects back. And I'll stop here not to further hijack the OP's thread.
Old 07-01-2014, 11:13 AM   #11
WAIT!!!
We're on our 4th camper and the longest we ever kept one was 4 years before that bug bit us again. Nothing helps, not even alcohol .
Old 07-01-2014, 11:15 AM   #12
Crusader's Avatar
lkicklight..... Get a Delta faucet .... lifetime warranty and easy to work on.
Old 07-01-2014, 12:45 PM   #13
WFD
The Deltas will be compatible with the existing RV plumbing?
Old 07-01-2014, 08:59 PM   #14
LKicklight's Avatar
Faucet
we have already replaced the head faucet previously, swapping the galley out with one similar should not be a problem at all...the one I have priced out already is 165 dollars and is chrome plated...
Old 07-01-2014, 09:18 PM   #15
B and B's Avatar
I just purchased a 2 handle Glacier Bay bronze finish for $45 for the bathroom in my park model. The single levers I have had are all messed up with lime and corrosion caused by antifreeze. The less expensive the facet works well. Enough pressure but flow rate conserves water when dry camping.
Glacier Bay | 1500 Series 4 Inch Bath Faucet - Chrome | Home Depot Canada
B and B
faucet
