06-30-2014, 10:18 PM
Single Lever Sin Faucet
On top of all that has happened since coming to Alaska, now the gally faucet is leaking around its base. Took it apart, no broken seals, cleaned it, greased it up well, put it back together, lasted one day, now leaking once more from around its base a sink level...Home Depot here we come tomorrow in Anchorage, AK.... when will it stop!!
kickstere
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
07-01-2014, 09:06 AM
So are you thinking of replacing it with a residential faucet? Or are you hitting Home Depot for parts or supplies to fix what you have?
Can any of these RV faucets be replaced with regular residential faucets? Never examined it, but I suppose there is nothing different to how the plumbing connects to the actual faucet, be it residential or RV specific.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
07-01-2014, 09:28 AM
Our unit had the (Plastic pullout/kitchen sink faucet),what a piece of junk! Replaced with a (Highrise ) faucet from HD. We replaced the plastic one in the Bath also with a (Single Lever) also from HD. Youroo!!
07-01-2014, 09:35 AM
I've noticed the faucet that came with our RV is lacking in the pressure and flow rate. Does going to the residential faucet help in this area? If it does I just might move up my plans on replacing ours.
07-01-2014, 10:04 AM
Note to self, if ever a trip to Alaska is made pack plenty of tools!
Hope things smooth out from here!
07-01-2014, 10:42 AM
It depends on how it is restricted (Screens/orifices) as to flow GPM. Now pressure is dependent on your incoming setting of your pressure regulator while on (City) water,and your pump setting while on (Stored Water). We have a (5gal) accumulator tank that eliminates the (Pump pulsation) also! Youroo!!
07-01-2014, 10:48 AM
kickstere
I’m convinced ……… If your in a crusader, it will never stop !!
Thank god for my seven year extended warranty !!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
07-01-2014, 11:05 AM
WAIT!!!
Stop the thread, people keep one for seven years?
How does one avoid the upgrade bug that long....
07-01-2014, 11:09 AM
Originally Posted by Ford Idaho
WAIT!!!
The “upgrade bug” is a tough fight !! The warranty makes for a good selling feature.
07-01-2014, 11:11 AM
Plenty of water pressure while hooked up to house. I just noticed the faucet than came in the TT doesn't have much flow and when I talked to Palomino they said they are all like that. Without the faucet attached the main line seems to be ok. I plan to replace it at some point but if a residential would make a marked improvement then I would push some of the other improvement projects back. And I'll stop here not to further hijack the OP's thread.
07-01-2014, 11:13 AM
WAIT!!!
We're on our 4th camper and the longest we ever kept one was 4 years before that bug bit us again. Nothing helps, not even alcohol .
07-01-2014, 11:15 AM
lkicklight..... Get a Delta faucet .... lifetime warranty and easy to work on.
07-01-2014, 12:45 PM
The Deltas will be compatible with the existing RV plumbing?
07-01-2014, 08:59 PM
Faucet
we have already replaced the head faucet previously, swapping the galley out with one similar should not be a problem at all...the one I have priced out already is 165 dollars and is chrome plated...
07-01-2014, 09:18 PM
I just purchased a 2 handle Glacier Bay bronze finish for $45 for the bathroom in my park model. The single levers I have had are all messed up with lime and corrosion caused by antifreeze. The less expensive the facet works well. Enough pressure but flow rate conserves water when dry camping.
Glacier Bay | 1500 Series 4 Inch Bath Faucet - Chrome | Home Depot Canada
B and B
