Old 11-10-2015, 11:53 AM   #11
Originally Posted by breezyhillfarm View Post
And unhook the city water and/or turn off the pump. The turn on the hot and cold faucets in the kitchen to get the pressure out of the lines. Turn off the electric element in the WH if you have one.
That is just the opposite of what I do and have done for years on the rare occasion that the relief valve seeps.
Old 11-10-2015, 02:49 PM   #12
And that's why we have many people on the forums...
breezyhillfarm is offline   Reply With Quote
Old 11-12-2015, 05:10 AM   #13
My house at Toronto had the same issue of water dripping slowly from the tap, what I did was just consulted a professional in commercial plumbing and mechanical services, Professional Plumbing Services in Toronto | Green City Plumber who sorted out the problem by replacing the valve connecting the tap as there was some sort of trouble in the valve which made the water to drip slowly rather than the normal speed. Hope they can help you too.
thhomascunningham is offline   Reply With Quote
Old 11-12-2015, 10:18 PM   #14
MNtraveler's Avatar
Slow drip from hot water tank release valve
The issue reported here was weeping at the pressure release valve. Household hot water heaters don't normally blow off their pressure valves (although it's there in case it's needed). These small RV units heating 6 +/- gals. in a tight space may weep a bit as indicated. It can be stopped or reset from time to time.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
hot water, tank, water, water tank
