Old 11-09-2015, 11:59 AM   #1
mikejm
Slow drip from hot water tank release valve
Forest River 320RD
Sent from my XT1254 using Forest River Forums mobile app
mikejm is offline   Reply With Quote
Old 11-09-2015, 12:10 PM   #2
slow drip
CAREFULLY, lift the valve stem, release a small amout of water and then close the valve. This has helped me in the past. If that does not do it, the valve probably needs to be replaced. Make sure the hot water is turned off so burning doesn't happen.
jpaskell is offline   Reply With Quote
Old 11-09-2015, 12:11 PM   #3
Operate the release lever several times to try to remove anything preventing the valve from completely closing. Might be built up with lots of calcium and need replaced. $25 for a new valve. Use caution in opening the valve if the water is hot.
rednek is offline   Reply With Quote
Old 11-09-2015, 04:03 PM   #4
mikejm
jpaskell & redneck, thanks for info on leaking tank. Am learning lots of repairs are do it yourself if just ask for help. mikejm
Old 11-09-2015, 06:36 PM   #5
You are most welcome. Let us know how it worked out. It is often helpful to let everyone know if a recommendation works. It helps others with the same or similar situations.
Old 11-09-2015, 06:54 PM   #6
And unhook the city water and/or turn off the pump. The turn on the hot and cold faucets in the kitchen to get the pressure out of the lines. Turn off the electric element in the WH if you have one.
2014 XLR27HFS
2006 Ford F450 Diesel Dually
2015 Harley Freewheeler Trike (Tara)
2004 Harley Road King Custom (Gemma)
breezyhillfarm is offline   Reply With Quote
Old 11-09-2015, 10:13 PM   #7
One quick question; is water unusually hot? If so relief valve may be doing what it is supposed to do. Just a thought.
Papa GLS is offline   Reply With Quote
Old 11-09-2015, 11:15 PM   #8
mikejm
It has fixed itself. The water drip was not hot
It has fixed itself. The water was not hot. Thanks for your help.mikejm
Old 11-10-2015, 04:21 AM   #9
MNtraveler's Avatar
Please see attached from Atwood if applicable for future reference. "Weeping" is a normal operation.
Name:	ImageUploadedByForest River Forums1447147315.021570.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-10-2015, 12:33 PM   #10
mikejm
The weeping has stopped so it must have been as you received. Thanks for the info. mikejm
hot water, tank, water, water tank
