Old 08-26-2016, 02:43 PM   #1
Smell coming up from toilet..
My sister is a seasonal weekender, lately she has noticed that after she dumps the tanks, and does the water and toilet tabs for the following week. When she comes back, first and second flush usually has the black tank odor. Nasty. She puts in 3 gallons of water for set up. Is there something she is doing wrong? Is there a reason for the smell? I have been camping in my 5th wheel for years, and never had an odor issue.
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 08-26-2016, 05:08 PM   #2
Flush tank until clear to make sure tank is empty. Add deodorant and a few gallons of water after dump. Make sure a small amount of water stays above the flush blade in bowl to act as a water seal.
If by chance you empty tank completely the solids get rock hard and will cause clogging problem plus odor. Then fill tank 1/2-3/4 and drive around for a while so the water moves around to loosen the solids, let this water in tank for 24-48 hrs than flush again. Check roof vent for blockage. Bee +/or birds nests.
Good Luck.
mfMcFroggierPod is offline   Reply With Quote
Old 08-26-2016, 05:16 PM   #3
Good Luck.
They're seasonal weekender's, (TT stays in campground all season?), so I suspect they aren't going to be driving around awhile.
They need dump the black tank and then add a few gallons of water and deodorant before they leave for the week. Might also add some stuff to break down whatever's left in the tank.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 08-26-2016, 05:21 PM   #4
fonzie's Avatar
Since it seems that she is at a seasonal site and trailer never moves, I would put deodorant/tank cleaner in and fill tank and let sit 24 hours and then dump....that should help clean side walls.....
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 08-26-2016, 05:37 PM   #5
Head Rambler
The trick as eluded to above is to dump and rinse, and then to add the deodorant and about three gallons of water. let the water and deodorant sit until next dump.
She also may need to change deodorant brands or types.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-26-2016, 06:04 PM   #6
Awesome replies! She has a tank wand,, I will make sure she is using it. I will see if we can get up on her roof to check vent also. Her husband has MS, so it will be her and I. I appreciate all the replies, so helpful! I will keep you posted.
Old 08-26-2016, 08:41 PM   #7
Are you sure the smell isn't from the grey tank? Check the sink and shower traps to see if they have water in them. Also check under the sink for the air admittance valve, if it isn't working properly it will give you a smell. It is gross but just stick your head under the sink and see if there is an odor under there. The grey tank can get real stinky if it isn't flushed well. Good Luck.
shortkid is offline   Reply With Quote
Old 08-26-2016, 09:38 PM   #8
Shortkid, that is the only odor I have ever had..no, this is definitely coming from the toilet.
Old 08-26-2016, 09:57 PM   #9
Flybob's Avatar
Don't run the vent fan while flushing, It can pull tank odors into the unit.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-26-2016, 10:19 PM   #10
northstar1960's Avatar
if shes dumping every weekend then the tank isn't getting full and i'll bet solids are sticking inside . she needs to fill let sit all week while she is gone and then dump and flush IMO
northstar1960 is offline   Reply With Quote
