Old 06-16-2015, 11:47 AM   #1
Smell under sink help please
Help!! There is a terrible smell under sink. I have run water with soap & Clorox. Last night when we came home the entire living room stunk. I have a Sierra 2013 376bhok. My husband doesn't come until Thursday & I don't know what to do
Kyndell
Moonlighting is offline   Reply With Quote
Old 06-16-2015, 11:59 AM   #2
TSB
I have it too and have no clue. Have tried everything!
TSB is offline   Reply With Quote
Old 06-16-2015, 12:02 PM   #3
cdangel0's Avatar
Search behind cabinets and drawers for a previously alive mouse.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 06-16-2015, 12:09 PM   #4
fonzie's Avatar
Look under kitchen sink for an air admittance valve and tap it a bit, might be stuck open and let smell from grey tank back in trailer. see post. If defective might have to change it.
1913 Possible Broken Pipe?
Fonzie
Old 06-16-2015, 12:15 PM   #5
TSB
Thank you. I will check it out when I get home.
Old 06-16-2015, 03:47 PM   #6
TSB
Thank you so much. I bet that is it. I am ordering a new one and we will see!
Old 06-16-2015, 09:55 PM   #7
That link goes to a birthday page. What part do I need to order?
Old 06-17-2015, 05:20 AM   #8
fonzie's Avatar
If your valve is defective, then you need to order similar size. Here is one example from Home Depot
Oatey 1-1/2 in. ABS PTC In-Line Cheater Vent-39012 - The Home Depot
Fonzie
Old 06-17-2015, 05:32 AM   #9
Toy-aholic
I too had the same thing happen...replaced the valve, helped a lot but still had odor....turned out to be something nasty fermenting in the galley tank....I had always completely emptied grey & galley tanks when leaving campground...big mistake...now I add a gallon or two of water with a couple oz of liquid tank chemical and no more odors.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 06-17-2015, 12:26 PM   #10
TSB
Good to know. I just replaced the valve so I will now add water and liquid tank chemical.
Thanks for the help!
