12-08-2016, 11:55 AM
#21
Originally Posted by Iwritecode
I've never had to use the pressure relief valve on my HWH. We only turn it on when we need it (mostly for dishes) so it's not in use all that much. The water is always nice and cool when I remove the anode.
We only use ours as needed, like you, so I was surprised the rod was so consumed after only one season.
12-08-2016, 12:14 PM
#22
I did not have a 1 1/16" socket, but had a 27mm one left over from a foreign car repair way back. It also works.
12-08-2016, 12:45 PM
#23
I hadn't used my TT for at least 6 months prior to removing the anode rod. Not worried about heat it's the pressure that stays in there. Hence the relief valve.
12-08-2016, 12:54 PM
#24
Insert witty title here
I find that a 1 3/48" works good too.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
12-08-2016, 01:00 PM
#25
I like to use my 1.0625" socket. It is a 0.500" drive so I've got plenty enough leverage.
12-08-2016, 01:03 PM
#26
My 1 4/48" fits like a saddle on a goose.
12-08-2016, 01:11 PM
#27
Well there is a size I never heard of!
12-09-2016, 10:11 AM
#28
anode removal
To the guy with the wet shirt- LOL there is a learning curve to RV'S- I know a guy- heh heh -(me) who on his first trip with an RV - checked everything with his new toy at home, then went camping! when leaving camp and at the dump station, squatted down, pulled off the drain cap, only to learn that I had not closed the black tank handle when I had checked out everything at home!! and the stuff on my shirt was not white!
12-09-2016, 10:26 AM
#29
Thank you DeeWayne...I feel a LOT better now about the anode rod. OMG what a mess you had, and you were all ready to hit the road to home or on to the next campsite. Guess you had to hook up again and do a cleanup before getting into the truck. I always look at those valves, as I am sure you do now, to insure they are closed before I slowly pull off the cap; I have a vision of what it would be like if they were opened, so I try to be careful. Now I can put a name with my vision...sorry, but it's yours.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
12-09-2016, 10:36 AM
#30
Response to D B Travelers
Heh Heh- - might add-- my camping buddies who laughed at me- they are all afraid to "NOT CHECK" their black water valves or handles.- You never know when some camping "kid" or vandal might go by and pull it some night!! LOL
12-09-2016, 10:52 AM
#31
Hence, why the "clear" adapter/elbow was invented.... most likely from someone who had the same thing happen ONCE.
With these, you can see before you remove the cap.
https://www.walmart.com/ip/29764319?...&wl13=&veh=sem
2011 Flagstaff 831 RLBSS
12-09-2016, 10:57 AM
#32
Or someone who you pissed off at the campground by not minding YODB!
Might be the same guy who strategically placed the open can of sardines under your rig in an area with a Racoon infestation.
12-09-2016, 11:27 AM
#33
If you have time and access you could always wire tie a harmonica somewhere in the engine compartment.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
12-09-2016, 11:41 AM
#34
I have been showing my guys here. We are laughing too hard.
12-10-2016, 08:07 PM
#35
Too old to be too smart
I found that one of the four "ends" (1-1/16") of my truck's four-way "cross wrench" lug nut remover was a good fit for my anode rod, and allowed me to remove it with very little effort.
Keep in mind that the truck version has larger sizes than the automotive variety. It looks like this:
https://www.amazon.com/Performance-T.../dp/B0002KNYVU
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
12-10-2016, 09:22 PM
#36
This ad-on valve has helped others minimize the amount of surprise:
Twist On Waste Valve, 3 - $18.65
https://www.walmart.com/ip/VALTERRA-...-inch/44164893
Not as good as the harmonica but.......
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
