Old 07-04-2015, 12:27 PM   #1
Solaire 317bhks water pump wont pump H20
Hello everyone,
I am a new TT owner and I'm having a difficult time getting my water system sanitized and my fresh water tank going. I have filled the tank once and them emptied it by draining the low point and tank drains. Next I mixed the santizing solution and put that in the tank and filled the fresh water tank. I then opened all the faucets and went to turn on the pump. HERE is where my questions come... The pump sounds like it is running, but no water is coming out of any of the faucets. I am a bit concerned because now my fresh water tank has the bleach solution in it and I cant get it running thought the lines. Any help would be great, thanks in advance.
admrealhomes is offline   Reply With Quote
Old 07-04-2015, 02:04 PM   #2
Have you had any water flowing through your faucets before ---- i.e. did you hook up a hose to the city water connection and establish water flow through the trailer?? If not, you just may be slowly filling up the system??? Your water heater will hold six gallons.
Just a thought for you ---- how long did you let the pump run?
bruceatlam is offline   Reply With Quote
pump, water, water pump
