Are you sure your bypass valves on your water heater are in the correct position? This will cause your issue.
Assuming you don't have an on demand water heater, most folks complain the water is too hot.
The other thing it could be is if the outdoor shower spigots are on and the shut-off on the head is on, the hot and cold water will mix in the plumbing causing warm water only issues.
