Old 05-21-2012, 10:49 AM   #11
Originally Posted by KRS View Post
I don't see where you said that you filled the RV system with water, did you?
Did you vent the water heater tank?
The fresh water tank is full of water and no i did not vent the tank before i filled it after i ran it without water.
shrimper is offline   Reply With Quote
Old 05-21-2012, 10:55 AM   #12
Originally Posted by Taranwanderer View Post
A semi-related question here: I'm currently camping at beautiful Otter Lake and I decided to try the electric water heating element. I was surprised that it seems to get the water hotter than the propane does! So my question is, can the electric element be left on as long as there's water in the tank, or should I be turning it off to give it a break, like if we're not going to be needing hot water for a few hours? Thanks!
It will turn itself on/off as needed, so no worries. There is still a thermostat.
I keep our electric on all the time. Occasionally, if I am showering, I will also turn on the gas for a quicker recovery.
Laura is offline   Reply With Quote
Old 05-21-2012, 10:58 AM   #13
The fresh water tank is full and no i did not vent the hot water tank before i re-filled it after the dry fire.What difference would not venting make?I opened up hot water line on faucet and steady flow of water comin from hw tank since dry fire.
Old 05-21-2012, 11:02 AM   #14
KyDan's Avatar
Shrimper, you say you have to fix this so let's get started--
You'll need a multi meter and a few basic tools.
See the photo in message 2 below by iggy??
See that black rubber cover right below the water pop off valve?
Under there are the 2 over temp reset buttons.
Since you have pressed them with no luck it's time to dig deeper.
Make sure 120v power is OFF. Either by circuit breaker in your main panel
or better yet, unplug the water heater. Many are simply plugged into an
outlet that is located on the back side of the water heater tank.
This is not accessible from outside water heater hatch. Inside probably.
Once power is fer sure off, remove that black rubber cover.
Under the cover you will see the 2 over temp buttons which are part
of the thermostats.
Note there are 2 and these are completely separate.
12v gas is totally independent of the 120v electric.
You can use either one or both at once.
Once you have the rubber cover off, you can see the white reset button.
Push both.
Look at the photo in post 15 in this thread--
hot water problem (SOLVED)
Note the left side fusable link is burned out.
Make sure neither of yours are burned out.
Pull the 12v power fuse on the water heater momentarily. This might reset
it.
Now after making SURE your tank is full of water, and pressing the
white reset buttons under the rubber cover, try again.
Turn on the 120v and you should hear the electric element sing quietly
as it's heating water. Much like a pan of water will sing on a stove when
the water is heating.
Also try the gas and report back what you find.
Tell us what if anything worked and we'll go from there.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-21-2012, 01:49 PM   #15
Iggy's Avatar
Yes you can
Old 05-21-2012, 08:45 PM   #16
of the thermostats.
Push both.
it.
Thanks for your help.I will give er a try tomorrow evening and report back what i come up with .Im stumped on whats going on ,i figured i would just have to reset the eco/thermo but no luck.Thanks again for your time,i really appreciate it
Old 05-22-2012, 12:53 PM   #17
of the thermostats.
Push both.
it.
So i did what you told me .i took off cover and tried pushing (red reset buttons on my heater) with nothing happening,.Both fusable links are fine.refilled tank and tried to run in electric with nothing happening .Same for gas.I then took multimeter and tested .The one on left facing the back of hw heater outside of trailer tested good,both top and bottom parts of it all read zero's in ohm's mode.The one on the right however with the red reset comin out of it(top part) never had continuity and stayed at 1 on meter while the bottom part of it read all zero's.
Old 05-22-2012, 01:20 PM   #18
I now have hot water using electric element but still no gas so im assuming that i got the eco/thermo for the gas side burned up?
Old 05-22-2012, 03:23 PM   #19
Herk7769's Avatar
That seems reasonable to me...
They are both pretty simple circuits.
Name:	AC diagram.jpg
ID:	14289   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-23-2012, 06:10 AM   #20
KyDan's Avatar
You should have 12v on both wires at the t-stat/hi limit switch.
Put one meter lead on ground and test each wire while it's plugged
onto the T-stat.
12v on one side but not the other means the T-stat/hi limit is still
kicked out and possibly damaged. I doubt this but check it.
No voltage on either side means a fuse or loose wire or switch is still off.
You can also jump across the t-stat/hi limit to see if the burner
tries to light.
Be careful!! One side is 12v but the other t-stat is 120v AC!!
Make sure you know which is which!
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
led pad
