Old 08-09-2012, 03:30 PM   #1
great white's Avatar
Sonovacheapmuthalovin.......bloody cheap plumbing!
Well, late into the season, but I just "dewinterized" the trailer. We weren't planning to use it this year but things change.
2011 Flagstaff classic superlite 831rlbss.
Last fall, I blew the lines out (opened all faucets), shut off the HW tank, removed the filter, anti freezed the pump and lines and then drained all the tanks one last time.
Sounds good, right?
Not a frickin' chance!
I fill the fresh tank and snap on the pump to start purging the lines and all I can hear is "sshhhhhhhhhhhhhhh!" under the kitchen sink!
AUUUGGHHHHH!!!
After several minutes of sopping up water I crawl under and have a look.
The hot water line has popped apart at the 90 degree fitting to the faucet.
What?
I pull it down and discover the FR in their infinite wisdom has installed a "check valve" in the hot water fitting. Basically, a few drops of h20 was trapped behind it and popped the cheap fitting apart. Stupid design. Now way in heck to get all the water blown out because reside water runs down the line and collects on the check valve.
Well, it looks like PEX line, maybe I can install a PEX fitting and be done with it. Off to the hardware store.
I get back and try to cut the clamp off. No dice. The one place they didn't seem to cheap out is the pinch clamps. Side cutters and a fair bit of swearing finally wins the day. Now grab what's left of the buggered fitting and pull. Nope, not comming out. Another round of curses. Look for some cutters. Nothing will cut the line becaus eall my cutters are straight anvil. More cursing.
Grab the garden loppers and SNAP!
The fitting is off and the line is clean.
FINALLY! it's going my way again.
Slide on the Pex fitting and screw it in to the faucet.
Turn on the water and;
"SHHHHHHHHHHHH!"
More cursing and more water sopping.
Seems the lines look like PEX but are just off enough not to be PEX sized. Proprietary FR stuff I'd wager.
More cursing.
Back to the hardware store and find a sleeve that will open and stiffen the line enough that the pex fittings will work.
Home again, install the fittings. Turn on the water and:
JOY! no Shhhhhhh.
But...........
Drip, drip, drip.
Now the cold fitting is leaking. Crank it down and it leaks less but still leaks.
Grrrrrrrrr.........
Well, lets check the faucets.
Turn 'em on and;
Leaking at the base, top and body!
AUUUGHHHHHHHHHHHHHH!!!!!!!!!!!!!!
A closer look reveals the entire faucet is plastic!
Plastic?
you gotta be kidding me.......
So I decide that's just about enough. Off to the hardware store again. This time no messing around.
Down the plumbing isle I grab the proper pex cutters, all new pex fittings and a new Peerless kitchen faucet with the sprayer hose.
Pay for it all and head home. Just over a hundred bucks taxes in.
back at the trailer, the pex cutter makes short work of FR's crap parts and workmanship. It all flies out the door and across the driveway in one big pile. In goes the new faucet and PEX lines/fittings.
Fire up the pump and:
AHHhhhhhhh..........
Sound as a pound.
No leaks anywhere, faucet works smooth a seamless.
It all even looks better.
All this heartache because some stupid builder/engineer decided to put a check valve where one had no earthly business being in the first place....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-09-2012, 03:56 PM   #2
wmtire's Avatar
I feel your pain, especially on the faucet. My 831's el-cheapo faucet actually ruined my countertop, that FR replaced under warranty.
I did as you....... went to Home Depot and bought a real faucet, and shouldn't have to worry about it again.
Input needed on Flagstaff 831RLBSS
Now you got me wondering about the check valve, which I don't guess I noticed while lying on my back replacing the faucet. Of course, down here in Louisiana, things freezing aren't something we worry about too much.......on either of the two days a year that it could happen.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 08-09-2012, 05:15 PM   #3
DDC
DDC's Avatar
It really makes you wonder how low quality will go, all because they can't seem to reach the bottom with cost cutting.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-09-2012, 05:50 PM   #4
If you removed the check valve, I hope you installed a a regular valve. Otherwise, when you go to winterize, you will back feed the water heater and put antifreeze in it. The check valve eliminates to need for a valve on the outlet side of the water heater. Not sure which is cheaper, just one less valve.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-09-2012, 10:36 PM   #5
Nope. Tank is shut off and drained when winterized.
It has a shut off on the inlet and the outlet ofthe heater as well as a bypass.
Nothing getting in there.
The "valve" at the base of the faucet is pointless other than to trap "freezable" water in there and catch you with your shorts down.
Doesn't matter if it gets any "backwash" antifreeze in there anyways.
Spring routine is to thoroughly flush and sanitize anything that water touches.
That includes the hot water tank and lines...
Old 08-10-2012, 02:35 PM   #6
VinceU's Avatar
Just curious, was the check in the hot supply, cold, or a combination of both leading to the faucet. I know its plumbing code a vac breaker or check valve must be installed in line with any fitting which may provide a connection for another device. IE: a dishwasher or supply for a washer or any device like that. It will prevent contaminated water from backflowing to tanks or hose. Then you must blow down through the fitting.
Old 08-16-2012, 06:04 PM   #7
ejohnson03's Avatar
This is amazing...
I have a 2009 Roo 21SS and had the exact same problem with the Hot line 90 degree thing blowing apart.
And the cheap faucet, cold valve, would not shut off.
I bought a new faucet at Campers world, and the install went perfect.
Still trying to address the Hot line connection.
So, it is not a Pex connection?
And you need a special tool to crimp the new Pex replacement onto the tubing?
Crap, that is a lot of dough to put out for a simple connection.
I'll probably will never need to use that tool ever again.
Oh wait, there is still the bathroom and outside shower.
Well, off I go to home Depot.
Thanks for your post...
2009 Rockwood Roo 21SS
1994 Chevy K1500 4x4 Ext.
ejohnson03 is offline   Reply With Quote
Old 08-16-2012, 06:17 PM   #8
funkyJunk's Avatar
I'm going to recommend something that I never leave home without now. Rescue tape is AWESOME. I use it for all kinds of stuff from fixing electrical wires, repairing leaky pipes, mending scuba gear etc. The list goes on. This stuff really works and you can patch a leak and easily save a camping trip.
Link:
RESCUE TAPE Self-Fusing Silicone Tape ~ BLACK: Amazon.com: Sports & Outdoors
2013 Palomino Columbus 385BH
2011 Ford F350 DRW 6.7
funkyJunk is offline   Reply With Quote
Old 08-17-2012, 05:30 AM   #9
Originally Posted by ejohnson03 View Post
This is amazing...
It's not PEX line, but pex connectors worked on mine.
What I did was find 90 degree faucet connectors that had a compression type fitting on one end. Basically, a pex connector without actually being pex.
You cut the line off flush (I bought the cutting tool for PEX lines, 15 bucks), then insert a small "tube sleeve" tat comes with the fitting package which reinforces the line and push it in to the fitting until it bottoms out. The sleeve keeps the line from squeezing down too small.
The other end of the fitting screws on to the faucet like a regular fitting.
So, the faucet was something like 65 bucks, two fittings at about 5 bucks a piece and the cutting tool for 15 bucks. Once taxes were in I came out at around 100 bucks.
I did buy pex line, but returned it after I got the red and blue lines to work with the fittings.
Old 08-17-2012, 07:28 AM   #10
ejohnson03's Avatar
Well, it went better than expected.
Bought a 90 degree Sharkbite fitting.
Cut off the crappy part on the Hot line, screwed the new fitting onto the Faucet, slipped in the tubing on the other end, and wah lah.
Problem solved.
Oh, the new faucet I installed looks way better than what came with the trailer, and no dripping.
