Old 03-06-2018, 06:56 PM   #1
Sorry I know this is probably asked somewhere...
I have a 2013 m-29bhbs and I took the anode rod/plug out for winter and being the brain surgeon I am I tossed it thinking I know I need a new one because it was falling apart BUT now I have no clue what one I need. Can someone please help??
ffron69 is offline   Reply With Quote
Old 03-06-2018, 07:01 PM   #2
I think there are only two water heater manufactures. Very easy part to replace. Any rv parts department will have them. I don't like to use the word "standard" but its pretty close I think. Knowing the manufacture of water heater will shorten your search.
Kimber45 is offline   Reply With Quote
Old 03-06-2018, 07:02 PM   #3
I think Anodes are pretty standard. Check what brand water heater you have - Atwood or Suburbon. Shop the Amozon or Walmart website
PhilG is offline   Reply With Quote
Old 03-06-2018, 07:05 PM   #4
Thanks the trailer is over an hour away from the house I was hoping to order one without having to drive up there and see it....should've thought about it when I was at the trainer today LOL
Old 03-06-2018, 07:08 PM   #5
BuzzWolfAR's Avatar
They aren't very expensive. Buy one of each from Amazon and return the one that doesn't fix.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 03-06-2018, 07:11 PM   #6
wmtire's Avatar
The Atwoods have aluminum tanks, and therefore don't use an anode rod or come with one, as per this previous thread link.
Is this hot water heater anode condition considered normal?
It's the Suburbans with a steel tank uses the anode rods.
These are fairly standard, regardless of tank size. Here is an amazon link to this anode rod.
https://www.amazon.com/Suburban-2327.../dp/B003VAYRNM
The OE anode rod that comes in their heaters is magnesium. You can also get an aluminum kind, if your water is too hard on them....but I would recommend staying with the magnesium so it can protect your tank better.
Suburban provided us with some great videos, including one on the anode rod. You can find them here:
Suburban Water Heater Video Guides
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 03-06-2018, 07:15 PM   #7
wmtire's Avatar
Also if you have a Suburban water heater with an electric heating element in addition to the propane burner, this thread may help too:
Suburban's electric switch and much more
Old 03-06-2018, 07:27 PM   #8
thank you all very much I guess I should have been more specific it does have propane and electric both. I also know it has an anode rod because it was falling apart in pieces when I pulled it out.
Old 03-06-2018, 07:33 PM   #9
wmtire's Avatar
The amazon link in post #6 above should get you fixed up. You can also go to about any RV dealer that has a parts dept, and get the same. The part number is there in the link.
Old 03-06-2018, 07:53 PM   #10
bikendan's Avatar
Suburbans need anode rods, Atwoods don't.
Equalizer WDH
