03-26-2016, 06:13 AM
Sos... lol dometic 300 toilet
I just wanted to touch base with you folks, our toilet is clogged andi read an article about using hot water to break it up. The black tank gage shows empty still so it is not backed up... I think my dear wife in her tummy trouble used to much tp... and yes it is rv tp... will the hot water hurt anything? I just don't want to be a newbie an take advice from a random blog and make it worse.
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
Eastern Carolina (Craven county)
03-26-2016, 06:20 AM
"On the road again"
I don't know that hot water would hurt anything, but I also don't know if it would help. We had grandkids staying with us once and had the same issue.
I found a sure cure that I keep in the "underbelly" now every time we go out - it's a "power plunger" - KISSLER & CO 57-2000 Plunger, Plastic, Fits Most Toilets - Walmart.com
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
03-26-2016, 06:22 AM
I can get a plunger we did not camp far from home... but I just did not want to boil water and put hot water in there and have it hurt something
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
03-26-2016, 06:25 AM
"On the road again"
I don't believe there is anything it could hurt by just using hot water.
Georgetown XL 378TS
03-26-2016, 06:28 AM
Depending on how much is in the tank and how much boiling hot water you plan on using the one thing to remember is plastic will swell/expand when hot.
Tanks are not very thick and can warp.
Hot water like from the water heater might be a better option.
03-26-2016, 06:37 AM
There is next to nothing in the black tank... but yeah the hot water from the water heater is pretty hot so I'll give a gallon of thst a shot
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
03-26-2016, 12:02 PM
A spray wand on a hose might work to break it up
03-26-2016, 12:07 PM
The hot water helped... and a long bamboo skewer... so far so good
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
03-26-2016, 12:14 PM
Water, lots of it is the toilet and black tanks best friend.
Step lightly on the pedal and let it fill up.
03-26-2016, 12:16 PM
X2
Fill the bowl when flushing!
03-26-2016, 12:34 PM
Long wooden skewer will free up the "neck" the TP is blocking.
03-26-2016, 12:44 PM
Dahagen
Make sure you NEVER leave the black tank drain valve open when camping. Only open valve to empty. I try and close the grey water valve the day before I dump the black tank and then after dumping black, re-open grey valve.
03-26-2016, 01:47 PM
Yeah we did not let it fill when flushing... showed my wife too... now we know
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
03-26-2016, 03:40 PM
Did the same thing when we were newbies. Used a horseshoe post to stir thing up.
We cannot play horseshoes ever without my DW asking, "which one is the $#it stick?"
Just close the valve, stir with stick of choice, fill with water and let it rip. Lesson learned, cheaply. Good luck. Enjoy your rig.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
03-26-2016, 04:17 PM
Try 10 lbs of ice while driving. The cubes help break things up, then melts. Also there are some additives will help clean the sensors, and break up the material. They are just for that.
There is also an expensive cure, there the run a camera into the tank and uses the a low pressure water jet to clean it to new condition.
03-26-2016, 11:00 PM
If you think there is still hard material in the tank near the toilet pipe, go to a hardware store and buy a packet of Rid X it is safe for all tanks. Fill your black tank to 1/2 and put in the packet let the Rid X work for 24 to 48 hours. It will digest the waste, you will be amazed at what will come out of a tank that you thought was clean. Rid X also will not cause struvites like many chemical waste digesters will.
If you have just flushed your tank put in the Rid X and let it in until your next or final dump for the trip, the longer the better.
03-26-2016, 11:15 PM
Simple rule, water is your best friend to prevent the brown pyramid of death.
Keep the black tank dump valve closed until you need to dump.
Fill toilet 1/2 way prior to #2 deposit.
Finish paper work and flush.
Fill bowl all the way and flush again.
Time for breakfast. Enjoy!
Edit: Make sure to use a drop in black tank treatment or you will be back asking why your tank will not drain.
TIP: A full tank drains much better than one that is 25% full. Stand on the flush pedal and look down the toilet with a flashlight. You will see the water level. You might need to stand there for a few to help fill the tank for ease of dumping the tank.
Put a new treatment in after dumping to control odor.
2015 F-250 FX4
03-26-2016, 11:38 PM
Don't give it a gallon - give it 5 or 10 gallons.
The problem is not toilet paper. The problem is insufficient water being added each time. Use lots of water each time. Generally the gray water tank will fill up well before the black water tank will, so don't worry about filling it up too soon. When emptying it, you want it pretty full if possible - with LIQUID mostly.
At this point you need loads of water to flush it out. Good luck!
PS: Just to double check - do you have a black water flush port on the business side of the unit? If so, that will clean it out for you, but you may have to use it for quite a while if "things" have hardened up inside, or flush out following a good soak inside with plenty of water.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
03-30-2016, 01:00 PM
Great info folks thank you... once I got it broken up and was able to flush again I started filling the bowl each time before an actual flush and so far so good. I am going camping again next weekend I will fill the black tank 2/3 and use the rid a couple days before... I was wondering if I should leave it in there and drive to the camp ground and then dump... only about 25 miles from home. But if the sloshing with the rid x would break up anything else? Or is that a bad idea?
Douglas B
2011 f150 XLT
2015 Grey Wolf 26RR
03-30-2016, 01:09 PM
Good idea. It's designed to hold it.
Land of 10,000 Lakes
2016 Forester MBS 2401R
