Old 01-23-2019, 05:59 PM   #1
Retired
MainelyUS's Avatar
Squeaky faucet
2017, 340RK: does anyone know the make of the lavatory faucet in this pic or how to remove hot water handle to fix an annoying squeak.
TIA
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is online now   Reply With Quote
Old 01-23-2019, 06:20 PM   #2
Best way to fix it is to replace it.
2015 2819VS,
2011 Tundra Supercrew
bruin is offline   Reply With Quote
Old 01-23-2019, 06:24 PM   #3
RangeMaggotBob's Avatar
Absolutely. Same one I have. Big plastic piece of crap. Been meaning to replace it, but never think about it 'til I'm camping. As far as removing the handle, I haven't looked at it that closely yet.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 01-23-2019, 06:28 PM   #4
Just before you turn on hot water, turn up the volume on stereo
hshaynes is offline   Reply With Quote
Old 01-23-2019, 06:30 PM   #5
My apologies, MainelyUS. I couldnt help it. Thats what we used to do many years ago when the car or teuck developed a squeak.
Old 01-23-2019, 07:29 PM   #6
bubbles's Avatar
The ones I've seen like that the handle is sitting on a sprocket and a screw from the bottom comes up through the middle of the sprocket into the handle to secure it.
Old 01-23-2019, 11:43 PM   #7
PhoneDude 8289's Avatar
I have one like that. I take the handles off, remove and grease the cartridge "O" rings a couple of times a year. The handle you use to turn the faucet on and off just unscrew. Grab the lever and give it a twist to the left, the rest is obvious. Be careful pulling the cartridges, the rubber seats under them are spring loaded. About a five minuet job. I use silicone food grade faucet grease found at home depot.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 01-25-2019, 03:14 PM   #8
Retired
MainelyUS's Avatar
Squeaky faucet
PhoneDude8289, thanks for the info. In the pic I wasnít able to remove the cylinder I think itís one piece and connected to the water supply. But I greased all the moving parts...it seems to do the trick so far Click image for larger version
2017 Columbus 340RK
Old 01-27-2019, 12:31 AM   #9
Originally Posted by MainelyUS View Post
PhoneDude8289, thanks for the info. In the pic I wasnít able to remove the cylinder I think itís one piece and connected to the water supply. But I greased all the moving parts...it seems to do the trick so far Attachment 195391
The cylinder will lift right out, may need a little wiggle, friction fit because of "O" rings now that you have that nut off. Ounce the cylinder is out you have access to the "O" rings and give it all a good coat of grease.
Joe & Beverly
2014 8289WS lifted
faucet
