02-14-2018, 07:02 PM
Sterilizing Plumbing
Hello,
We never use the fresh water tank so this question pertains only to hooking up to city water.
Can I safely sterilize the plumbing in my camper this way (or is there a better way):
1) Connect hose to camper water inlet.
2) Put a few ounces of plain bleach in the hose before connecting to the city spigot
3) Connect to city spigot and then turn it on.
4) Turn on faucets inside the camper to let both hot and cold water flow until no bleach smell.
Thanks,
Seakayaker
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
02-14-2018, 07:25 PM
It will not work as well as using the water tank. You will not get a good concentration of bleach to each area of the plumbing this way. Also you want to let the bleach sit in the plumbing for a few hours. Since you don't use water tank, why not fill it 1/3 add bleach, use water pump to fill plumbing let it sit. Drain tank then use it or shore water to rinse it out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-14-2018, 07:39 PM
X2 - go here for bleach concentration to use:
https://www.clorox.com/dr-laundry/bl...g-water-tanks/
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
02-14-2018, 08:07 PM
We use Hydrogen peroxide in our fresh water tank for "Spring Cleaning"!  Youroo!!
02-17-2018, 04:35 PM
Think about this: You can put Hydrogen Peroxide in your mouth safely. Would you put Clorox in your mouth? HP is actually better at killing germs
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
02-17-2018, 04:39 PM
Well, I don't put Clorox in my mouth. I put it in my plumbing. Then I rinse it out. Just like I put soap on my dishes, then I rinse it off.
BTW: My bottle of H202 says "For external use only." (Says you can gargle with it, but don't go swallowing it.)
2011 Traverse LT, 3.6L, FWD
02-19-2018, 07:43 PM
Sanitizing questions...
Hello...need some opinions / advice from those in the know, please. I have a 2015 FR Flagstaff 832IKBS travel trailer that is now winterized. We are heading out in 4 weeks and I need to know the best way to sanitize the lines after de-winterizing. We don't fill fresh water tank to take with us as we always hook up to campground supply which is "city" supplied. However, we do fill it with about 4 or 5 gals for rest stop flushing and hand washing. Right now, all my by-passes are "on" due to anti-freeze. Do I do a "full" de-winterizing, put anode rod back in w/h and fill or leave it bypassed and use only the fresh water tank? All replies appreciated and welcomed. Just wanting to do everything right and ensure all lines are sanitized. Thanks again for all the help.
02-19-2018, 09:29 PM
Download this:
Forest River Forums - Downloads - How To Winterize Your RV
There are more in the Library. See the tab at the top of the page.
02-19-2018, 09:50 PM
What he said ..X2
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
02-19-2018, 09:53 PM
Bleach will kill all germs that are harmful to humans. Hydrogen peroxide does not kill bacterial spores such as Norovirus and Clostridium difficile (C. diff). Since these two types of bacteria are nasty gastrointestinal bugs I recommend bleach for sanitizing RV plumbing. Like Flybob mentioned you have to let the bleach / water solution sit for a while.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
