Old 02-11-2012, 09:52 AM   #11
TURBS's Avatar
The sanitizing process is roughly as follows:
1. Drain the tanks: main, pressure accumulator, and heater.
2. Prepare a solution chlorine bleach: using 8oz of plain chlorine bleach for a 40 gallon water tank, dilute the bleach in a gallon of water.
3. Pour the diluted bleach solution into the water tank and fill the tank with water.
4. Turn on the water pump and allow the pressure accumulator to fill. The pump will run until it fills the accumulator and then will stop.
5. After the pump stops operating, open a hot water faucet and let it run until water starts running free indicating that the heater tank is full.
6. Let the hot continue to run until you smell the chorine. Shut off.
7. In sequence, run every hot and cold faucet valve in the RV until you smell the chlorine. As soon as you do, shut it off and go on to the next one.
8. Back fill the main tank and allow to sit for a few hours, or even overnight.
9. Drain the tanks again, refill with plain water and repeat steps 4 thru 7.
Old 02-11-2012, 09:57 AM   #12
jim44646's Avatar
It's a good idea to sanitize your wresh water tank evey so often. I use about 1/4 cup to 15 gallons of water. When doing so pump it through whole system and let set a 1/2 hr. or so. Dump fresh water tank fill with plain water and flush system
jim44646 is offline   Reply With Quote
Old 02-11-2012, 09:33 PM   #13
Drinkin beer on the beach
Rod Johnson's Avatar
Are you guys finding the chlorine attacks or oxidizes the metals at all? I filled my fresh water tank with a sanitizing solution that was supposed to be drinkable, too. I let it sit over a week, but became concerned about the metal parts in the water heater and pump.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 02-11-2012, 09:54 PM   #14
cheese53073's Avatar
Rod It's too weak of a solution and too shot of a duration to attack the metal parts.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 02-11-2012, 10:03 PM   #15
sherdep's Avatar
I noticed no one mentions the removal of the In House Water filter before sanitizing with Bleach - Dont forget to remove the Water Filter before sanitizing.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-11-2012, 10:27 PM   #16
Good point!
Rockwood 8293RKSS
Old 02-11-2012, 11:45 PM   #17
Fire Instructor's Avatar
Had the same thing, figured out a solution, but I STILL don't understand what was causing it!
For me, it had to do with water that had been heated in the water heater, and then allowed to cool down. Even if I drained the HW tank, the water smelled like rotten-egg the next time that I used it. so now what I do, when I get home, is drain the water heater, flip the WH bypass valve, and run some fresh, cold water through the hot water faucets, including the shower head. The shower head is the most distant water discharge in my entire water system. I catch the water in a pail, so that I don't fill the gray tank with water.
Not sure if this is the same thing that you are experiencing, but the solution works for me!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-12-2012, 06:30 AM   #18
Mountainmanbob's Avatar
not much effect seen
it would take a whole lot of chlorine
over a period of time
to do any harm
wash machines use bleach
jacuzzi's use chlorine
with not much effect seen
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 02-19-2012, 11:27 PM   #19
MotocrossCamper's Avatar
Thanks everybody! Thats exactly what it smells like, a sulfur or rotten egg smell! I will get some bleach run through it to sanitize and then I will try your idea Fire!
MotocrossCamper is offline   Reply With Quote
Old 02-23-2012, 10:54 PM   #20
kevinC's Avatar
If your hot water tank has a sacrificial anode then your problem is likely the water is becoming contaminated by the corroded anode and sediment created by the anode. Most sacrificial anodes are made of aluminum which expels a rotting egg odor as it erodes. Removing the anode, draining the tank, use a hose to flush out the tank, clean the anode, and, then leave it empty will most definitely solve the problem.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
