Old 09-01-2013, 08:20 AM   #1
Stinky toilet
On the past three camping trips, we have had a horrible odor coming from the toilet. We have a 2012 Sabre fifth wheel 32BHOK. Any suggestions? We always flush the tank and add chemicals. HELP!!!
bulldog203 is offline   Reply With Quote
Old 09-01-2013, 08:24 AM   #2
Chewie's Avatar
Check and see if you if you have a Dometic 300 series toilet. Label is behind foot flush. If so it's the toilet holding nasty water inside the bowl. Call Dometic and they will ship out a replacement really quick and there is a long thread in the plumbing section in general repairs and tech about this. Check out "tanks odors in bathroom."
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 09-01-2013, 08:54 AM   #3
QCCowboy's Avatar
Do a search on the geo method on the forums here. Havent had any toilet odors since I've been doing this method.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 09-01-2013, 08:55 AM   #4
I have a Dometic 310 toilet. When you sit on it sewage water leaks out.
Old 09-01-2013, 09:30 AM   #5
If its really a 310, it sounds like the bolts holding it to the floor were not tightened properly or they left out the gasket at the floor.
Old 09-01-2013, 06:56 PM   #6
Sharon455's Avatar
There was a thread last week about the 310. Like Chewie said, it's a known problem and Dometic has been sending out replacements.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 09-01-2013, 07:13 PM   #7
That was the 300.
Old 09-01-2013, 08:07 PM   #8
Sharon455's Avatar
Originally Posted by BarryD0706 View Post
That was the 300.
You are right. I stand corrected.
Old 09-02-2013, 07:37 PM   #9
Twisty's Avatar
http://www.forestriverforums.com/for...ion-42448.html
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 09-03-2013, 05:31 AM   #10
I have the Model 310. Took it apart, seal is cheap plastic and shifts around, bottom part was filled with sewage. Gross!!!
