Old 11-07-2013, 03:54 PM   #11
bubbles's Avatar
Your pump sounds as though it is functioning properly, even the stop and go (it's a demand pump). Typically, the pump is connected to the hard water lines and when it comes on the vibration is amplified throughout the camper. Installing a flexible water hose between the hard lines on and the pump (usually with a loop) will aleviate the issue to a certain degree. Should be quiet enough to tollerate. This action did take care of my hammering issue. Good luck
Old 11-07-2013, 05:42 PM   #12
If it happens on only one faucet the problem may be the faucet itself. Does it do it on city water? I know that older style faucets with loose washers can cause hammering. You may not have washers but something else may be loose in the faucet itself.
DSurette is offline   Reply With Quote
Old 11-07-2013, 05:47 PM   #13
kc8lvy's Avatar
My brother installed this one on his 5w and it works good.
Shurflo Accumulator Tank - Shurflo 182-200 - Fresh Water Pumps - Camping World
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 11-07-2013, 06:55 PM   #14
bubbles's Avatar
It's a demand pump and the pump will run till back pressure increases then shuts off. When back pressure is relieved the pump will again run. setting the faucet to a low flow state will cause the pump to cycle at sometimes a rapid pulse. You say it runs continuous with high flow set at the faucet. Sounds ok to me. One point; turning your pump on with all faucets off is a good way to check for leaks in the system. Just saying. Oh yeah, pull you aerator and check for cloging.
Old 11-07-2013, 07:23 PM   #15
Fulltime family RVer
Good questions. Is it just one faucet or all of them? And, does it do it on city water? i.e., is it the pump, the water lines or faucet?
Old 11-07-2013, 07:49 PM   #16
I've had this same problem for a few years now trying the mouse pad base, pump silencers, padded the water lines from the filter/pump area etc,. and this is why we stayed since at water/electric sites because of the hammering below our bed. Camping World has a sale on a Flojet water pump which I purchased because of all the good reviews(Sensor VSD 4.5 gpm). We stayed away from electric only sites because of the noise but I'm installing this pump next spring. Kind of pricey but should be worth it. I'll give it a review in the future threads.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
Old 11-07-2013, 10:14 PM   #17
El Camino Man's Avatar
I may try hooking to city water and see if the problem persists. I have a feeling its the pump doing what its supposed to do and Ill have to live with it...
1996 Ford F-250 XLT ECLB
Powerstroke Diesel, Automatic, 4wd
2003 Salem by Forest River 25RLSS
5er, 25ft, Super Slide
El Camino Man is offline   Reply With Quote
Old 11-08-2013, 08:01 AM   #18
If it does it on one faucet only as you said, I don't see how it can be the pump.
Old 11-08-2013, 02:47 PM   #19
Brother Les's Avatar
the sink is close to the pump and gets the full force of no pressure or back flow pressure very quickly. Hence the rapid on and off. the other faucets are farther away and the pressure because of the distance changes the action of the pump and out flow from the faucet. the kit sink may have a different aerator that also comes into play.
Brother Les
Old 11-08-2013, 03:12 PM   #20
I had to isolate some of the water lines by putting pipe insulation on the pex lines where they were hammering on each other or going through the run in the walls. It did quiet them down.
Pipeman is offline   Reply With Quote
pump, water, water pump
