Old 11-07-2013, 02:06 PM   #1
El Camino Man's Avatar
Stop Water Pump Hammering?
Hey guys. Im fairly new to RVing. One thing that just seems to really get on my nerves is when someone turns on a faucet halfway, the water pump will hammer (surely you guys know what I mean). Before anyone says something smart-ellic, yes the simple answer is to turn the faucet on all the way (and Id say the same thing if someone asked me)... but sometimes you don't need a full surge of water. Not to mention it helps conserve some fresh water.
Im not sure whats so annoying about water pumps to me... my previous camper was a 1981 Airstream. If you guys have used an older camper, you know what the "hum" is. Its the inverter and it hummed constantly as long as the camper was plugged in. It was way less annoying than a water pump IMO. Is their such thing as a silent water pump?
Sorry for my rambling!
1996 Ford F-250 XLT ECLB
Powerstroke Diesel, Automatic, 4wd
2003 Salem by Forest River 25RLSS
5er, 25ft, Super Slide
El Camino Man is offline   Reply With Quote
Old 11-07-2013, 02:12 PM   #2
Is it the water pump cycling that annoys you or is it making a loud hammering? If the latter, it could be that the pump needs to be isolated better. I mounted one of ours on a plywood platform thru the rubber grommets on the pump and then mounted the plywood on grommets also and cut the noise down significantly.
Old 11-07-2013, 02:13 PM   #3
Future Berkshire Owner
justlkn's Avatar
I have the same issue. Someone stated they installed one of these. I have not yet but I have heard they work.
SharkBite 22630LF 1/2-Inch Residential SharkBite Water Hammer Arrestor by Sharkbite http://www.amazon.com/dp/B00A8HV176/..._cq.Esb019REC1
justlkn is offline   Reply With Quote
Old 11-07-2013, 02:17 PM   #4
jtstromsburg's Avatar
As old coot said, make sure the pump is isolated from hard surfaces. Some mount thru an old computer mouse pad. Also, depending on camper age/design, the rigid piping may be the culprit. You can add two short pieces of flexible hose, between the pump and rigid piping.
How this helps.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 11-07-2013, 03:17 PM   #5
I got a good look at my water pump when I was winterizing it a few weeks ago. The pump itself has rubber feet and theyre screwed into the carpeted floor.
I took a look at that hammer arrestor. One review says he used it on his toilet in his camper with fabulous results. But at $30 a pop, Id need several to do the whole camper lol
I may try the plywood with rubber feet idea. I might even try putting some insulation over the top of the pump as that will absorb some noise too. But then It might also get too hot?
Old 11-07-2013, 03:20 PM   #6
Brother Les's Avatar
Make sure that you do not have a bleed off of pressure when the pump is off. When you do turn the pump on it will build up new pressure as the pump is turning and any air in the lines may cause some hammering.
Brother Les
Old 11-07-2013, 03:21 PM   #7
Put a accumulator in the pressure side of your system. At least 2-5 gallon size. Youroo!!
Old 11-07-2013, 03:23 PM   #8
Originally Posted by El Camino Man View Post
I got a good look at my water pump when I was winterizing it a few weeks ago. The pump itself has rubber feet and theyre screwed into the carpeted floor...I may try the plywood with rubber feet idea. I might even try putting some insulation over the top of the pump as that will absorb some noise too. But then It might also get too hot?
Just make sure you drill big enough holes that the screws don't touch the mounting board. Use flat washers and rubber grommets on the top of the board and under it. Same thing with the pump mount itself, make sure the screws are not touching the metal/plastic of the pump. Isolating the pump & mounts is the answer.
Old 11-07-2013, 03:38 PM   #9
Isolating it oughta fix the noise part of it but what about the chatter? I don't think my question was very clear lol. When I turn my sink faucet on about half, the water pump will kick off and on at a very fast pace. No other faucet will do it but the sink will. And of course once its either turned on full blast or off, the pump will either run smooth or shut off
Old 11-07-2013, 03:48 PM   #10
You might try mounting the filter upside down and use the filter canister as a small pressure tank to minimize the pump coming on as often. You can also buy a small tank.Amtrol Well-X-Trol WX-101 In-Line Well Pressure Tank 2 gal - FreshWaterSystems.com
pump, water, water pump
