Originally Posted by Duckogram
Try this: Whatever time you are using, reduce it by 50%. If you do not get water in your kitchen gray tank, the water may be backing up through a common vent. Your black tank may be building solids that reduce the volume over time. YMMV
This ^^^^^^
Even if your black tank isn’t building solids, your source water pressure could be higher than you are used to. Higher pressure will give you higher flow which will fill your black tank faster than before, if the pressure was lower. Water will rise up into the black tank vent, then begin to flow down into any vent that is tied into to the black tank vent and into the gray tank.
You can use the 50% reduction in time suggested by Duckogram, or you could use the same amount of time you always have, then go into the camper and slightly push down on the flush lever of your toilet. If water begins to come up into the toilet, you will know that the water has risen above the level of the toilet and is most likely running down into a connected vent.
Bruce
