Old 04-13-2015, 03:53 PM   #1
Retired Ford Tech
Question Suburban Hot water heater
I have a 2008 Georgetown with a Suburban DSI SW6d water heater. It is Propane only, with DSI. We are full timers and we have been in Arizona for 6 months. Everything was fine until this morning. My water heater fires off, but shuts down in 5 seconds. It relights right away but goes out again. I've reset the one reset button but no change. The flame is normal when it lights but something must be telling it to shut down. Any thoughts?
rvpezzano is offline   Reply With Quote
Old 04-13-2015, 04:07 PM   #2
wmtire's Avatar
How's your propane supply?
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 04-13-2015, 04:08 PM   #3
TURBS's Avatar
How clean is the burner flue?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-13-2015, 04:16 PM   #4
Retired Ford Tech
water heater
I have propane, the stove works fine, the flu looks OK.
Old 04-13-2015, 05:04 PM   #5
If the flame sensor looks tarnished, you can clean it with Scotchbrite or some fine sandpaper. Be very careful to not crack the porcelain. The flame signal is very low level signal.
Filthy Beast is offline   Reply With Quote
Old 04-13-2015, 05:12 PM   #6
Herk7769's Avatar
Thinking in this direction as well. Flame sensor or control board.
Though to be complete, low propane pressure could also cause initial light; then flame failure.
HAM CALLSIGN - KC3FFW
Old 04-13-2015, 05:40 PM   #7
Retired Ford Tech
I removed the burner and does the spark ignitor double as a flame sensor? there is nothing else in the chamber.
Old 04-13-2015, 07:00 PM   #8
Herk7769's Avatar
Yes; there is a low current (1.5 MICRO amps) that passes through the ionized gas in the flame to ground. No current; no flame; the control board shuts the gas off.
Cleaning the electrode might help by exposing unoxidized metal so there is more "good" surface area to expose to the flame.
Might want to check the spark gap too. The tip may be burnt off and the gap is too large.
File Type: pdf Suburban_Water_Heater_Service_Manual.pdf (3.60 MB, 42 views)
Old 04-13-2015, 07:32 PM   #9
Retired Ford Tech
Thanks to all. I removed the burner assembly, steel wooled the electrode, checked the gap, reinstall it, and BINGO. I guess they had enough build up to reduce the amps to the board.
I'll know next time.
Old 04-13-2015, 07:42 PM   #10
Crockett's Avatar
Could be the grounding of the burner assembly. The spark has plenty of voltage but the sense circuit not so much. Quite possibly removal and install was the fix.
Crockett is offline   Reply With Quote
heater, hot water, suburban, water, water heater
